Old 07-16-2011, 08:02 AM   #1
palmtreegirl's Avatar
2008 25' Safari FB SE
Medina , Ohio
What is this?
What is this? Does it come apart? What is causing it to leak? How do I take it off and still use the shower?
P.S. The hose attached is not the issue - water comes from the holes in the square/round thing.
Name:	camper shower.jpg
palmtreegirl is offline   Reply With Quote
Old 07-16-2011, 08:42 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
That is a vacuum brake to prevent water from siphoning out of the tub.
Most likely replaced as a unit. If it is not leaking while the water is on there should not be a problem. It will release the water in the hose when the water is turned off.
2004 Excursion 4x4
Old 07-16-2011, 08:47 AM   #3
Medina , Ohio
It leaks while the water is on - wastes water terribly. I'm going camping tomorrow with no sewer hook-up - is there a quick fix?
Old 07-16-2011, 09:06 AM   #4
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Palmtree Girl,
That goes to your shower head right? In our '87 it lets the water drain from the shower head once the water is turned off, but does not leak when the water is turned on. I know you can remove the shower head hose. You might have a bad rubber washer, gunk in it that is letting the water leak while running, or it may be plub just shot. It is probably spring loaded and closes when it senses water pressure and opens once the pressure is let off.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 07-16-2011, 09:14 AM   #5
DEITZ645's Avatar
Palmtree Girl,
I think I found the technical name for that gizmo in your shower...Vacuum Breaker For Shower
Vacumn breaker for shower 600332 [600332] - $16.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 07-16-2011, 09:33 AM   #6
Medina , Ohio
Thanks - so not to sound stupid - does the round part screw off the square part? I would hate to start trying to get it off and have it break - that would be bad news because tomorrow we go camping.
Old 07-16-2011, 09:40 AM   #7
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
I believe so. I would hold the square part with pliers, and attempt to unscrew the fitting. Don’t trust the screws in the square part to hold while you twist on the hose.
If you get it apart, a good soaking in CLR might clear the debris and let it seal. Pouring a little CLR in the openings with out removing the hose might do the trick too. Neither would be a permanent fix, but it would get you camping for now.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 07-16-2011, 09:47 AM   #8
DEITZ645's Avatar
Palmtree Girl,
Good Advice from jdalrymple. The top "chrome" part is plastic so be gentle with it and I would avoid using pliers on that part. Try it with your hands first. Our '87 is on a permanent site 4 hours way so I can't get you a picture of the exact same thing that you have but here is a picture of basically the same thing from the shower in our '06. This picture is with the shower head hose removed from the fitting...
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 07-16-2011, 09:52 AM   #9
DEITZ645's Avatar
More Advice
Palmtree Girl,
If you can clean it and it stops your leak great. But if you have to replace it you are probably going to have to remove it from the 90 fitting. For that you will definitely need two wrenches; one to remove the fitting and one to "backup" the 90 fitting that is attached to the wall. And be sure to use some teflon tape on all the threads to prevent leakage.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 07-16-2011, 10:58 AM   #10
Medina , Ohio
Thanks Everyone!
I got the round thing off and re-attached the shower hose to the elbow. Works great and no leaks! YAY!
I'll work on replacing that other part later, at least I can camp without wasting water now.
Old 07-16-2011, 11:45 AM   #11
HowieE's Avatar
Images: 12
As long as you do not let Ralph Nader into your trailer you are home free.
The whole ideal of a back flow preventer in this application is Gross Overkill.
The city water system would have to fail and pull a vacuum on your trailer while the wand was lying in a tub full of water. About as likely as having a 94 year old lady have to remove her diaper in order to fly. But then again that did happen.
2004 Excursion 4x4
Old 07-16-2011, 12:20 PM   #12
DEITZ645's Avatar
Nader's Raiders
I still hold a grudge because Ralph "killed" the Chevy Corvair.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 07-16-2011, 12:53 PM   #13
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Especially after Chevy fixed all his complaints with the suspension. He never mentioned that.
Vaughan
Old 07-16-2011, 09:16 PM   #14
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
I do not use a vacuum breaker and have experienced no problems. With the vb I had low pressure problems and drippage.
4RXLA is offline   Reply With Quote
