Old 11-10-2013, 12:59 PM   #1
1964 26' Overlander
Cedar falls , Iowa
what is this?
Wondering what this is and if I need it or can I take it out. There is a attachment to hook up to the water supply but it is not hooked up. Any help would be appreciated.
OK every time I try and add an attachment it crashes so I will try to explain....
Round tube sticking up directly behind toilet seat. The top twists off. Is it a way to supply the toilet bowl with water other than the sprayer?
Bluemoon64 is offline   Reply With Quote
Old 11-10-2013, 01:41 PM   #2
That part is called a "vacuum breaker".
Old 11-10-2013, 03:30 PM   #3
1964 26' Overlander
Cedar falls , Iowa
What is its function? Do I need it?
Old 11-10-2013, 04:02 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Definitely essential for proper operation. Do no remove. I keeps a vacuum from building up in your system.
MICHAEL
Old 11-11-2013, 06:56 AM   #5
AWCHIEF's Avatar
Images: 33
Sorry about the spelling, blame it on not double checking the spelling checker.
MICHAEL
Old 11-11-2013, 07:56 AM   #6
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Welcome to the forums.
It lets whatever plumbing it is connected to suck air into the pipes, without letting fumes or liquid from the pipes back into the living space.
They are used in various applications. One common spot is a faucet, to prevent a connected hose from holding water when the faucet is turned off.
If it was connected to the commode, perhaps it allowed the water trapped after the flush valve to drain into to the bowl? Just a wild guess.......
But, if I am reading your post correctly, it is not connected to anything now?
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 11-11-2013, 08:30 AM   #7
1977 Argosy 24
Milltown , Wisconsin
It should be connected to the drain line of the black water, or directly to the black water tank. It lets air in when the tank is drained, or the toilet flushed, to replace what is draining out.
ventport is offline   Reply With Quote
