Old 04-20-2009, 08:44 PM   #1
1992 34' Excella
1972 31' Sovereign
Spartanburg , South Carolina
What is extra hose inside Thetford Aqua Magic
Hello All
I just completed an overhaul of my Thetford Aqua Magic due to a leaking valve in our '92 34 Excella. While I had it out, I installed a seal kit (#08368). Everything was fairly straight forward except I don't know what the hose between the rim and the blade housing is. There is a hose from the valve up to the siphon break, and a hose from the siphon break to the rim. All that makes sense. There is another hose from a hole near the rim that goes down to the blade valve housing. What is the purpose of this third hose? It seems like it introduces a path for fresh water via the blade housing beneath the blade seal into the tank. Is it for cleaning out the blade housing? Is it a slow-leak overflow for the bowl?
Thanks, JH
Julian H is offline   Reply With Quote
'76 Thetford Aqua Magic? Mr. Decent Sinks, Showers & Toilets 4 04-13-2011 02:35 PM
Upgrade Thetford Aqua Magic V Toilet ?? 2dabeach Sinks, Showers & Toilets 12 04-14-2009 02:55 PM
1972 Thetford Aqua Magic 30 cameront120 Plumbing - Systems & Fixtures 5 05-19-2007 07:59 PM
1972 Thetford Aqua Magic 30 cameront120 Sinks, Showers & Toilets 2 04-25-2006 08:19 PM
Replacement Toilet for Thetford Aqua Magic? JeepinAudiophile Sinks, Showers & Toilets 1 09-20-2004 11:05 AM
