Old 01-04-2020, 10:22 PM   #21
2016 25' Flying Cloud
Vadnais Heights , Minnesota
After each use we spray this on the shower walls. Works great to keep it clean while traveling and easier to do deep clean upon return. And is eco friendly !
Earth Friendly Products ECOS Shower Cleaner with Tea Tree Oil, 22-Ounce (Pack of 2) https://www.amazon.com/dp/B004YIXADI..._BnweEbZK6PCGP
Fipp is offline   Reply With Quote
Old 01-04-2020, 10:30 PM   #22
2018 26' Flying Cloud
Warner Robins , Georgia
Mrs Meyers for a clean shower
We use Mrs. Meyers baking soda cleaner. non scratch, non kill you smell, doesn't kill probiotics in your tanks and rinses quick. Both in the shower and toilet and all the sinks. Mrs. Meyers vinegar cleaner for the shower door (roll up model)
jrwayne is offline   Reply With Quote
Old 01-04-2020, 11:01 PM   #23
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
We have used BubbleUp for years. Before you use anything make sure it is compatible with the plumbing seals and gaskets. When clean, spay everything down with WD 40 and it will almost not require future cleaning.
guskmg
Old 01-05-2020, 02:07 AM   #24
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I use Spray-Way glass cleaner from Costco to clean my shower and I use it on the vinyl floor too.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 01-05-2020, 04:04 PM   #25
Livingston , Texas
We use Tilex daily shower spray.
2019 Flying Cloud 27FB
2011 F350, SB SCREW SD
Be thankful were not getting all the government were paying for Will Rogers
dzwiss is offline   Reply With Quote
Old 01-07-2020, 09:11 AM   #26
2019 27' Globetrotter
Denver , North Carolina
No Water Shower Cleaning
I used "Gel-Gloss" recommended here on a another post. I wanted to clean the shower walls while my trailer was winterized, so no water. Worked great and made the shower look like new. Works on multiple surfaces.
It also took the water deposits off the chrome and inside of the shower door although they don't advertise it for use on glass. Then applied Rain-X to the glass and a squeegee to the shower.
Dave S
link2dks is offline   Reply With Quote
Old 01-12-2020, 10:45 AM   #27
2015 23' FB International
Bellingham , Washington
I use Mrs. Meyers and a squeegee and it keeps the glass door sparkling clean.
Flygirl123 is offline   Reply With Quote
Old 01-12-2020, 11:19 AM   #28
2017 28' Flying Cloud
Newmarket , Ontario
Originally Posted by wbrisett View Post
We also make sure we squeegee and wipe down the shower after each use.
Ditto.
IrkdScientst is offline   Reply With Quote
Old 01-12-2020, 12:21 PM   #29
carlsbad , California
Cleaning shower
For the walls/seat/floor, I use a squeezed out Magic Eraser with a few drops of Dawn. Then wipe it off with a damp towel. We squeegee after each use like others have stated to reduce moisture and leave the vent open.
TKNews is offline   Reply With Quote
Old 01-13-2020, 12:01 PM   #30
2017 30' International
Middletown , Ohio
While living in our Airstream for 6 mons, we learned that bar soap leaves an incredible amount of residue, even when using a squeegee. That and the often hard water at most locations will leave an incredible amount of film that attracts dirt. We converted to body wash with good rinsing agents and that problem was eliminated (shampoo also leaves little residue). We use a squeegee after using the shower for the day and we keep a microfiber towel on the floor outside the shower to absorb remaining drips from the door. We then use the towel to dry off the shower stall, door, and controls. When possible we hang towels outside to dry. All this helps to minimize humidity inside the trailer. We have found we do not need to use cleaners often with this routine. However, we occasionally use Windex and paper towels, and if we or our grandkids happen to have really dirty feet, will use soft scrub on the floor of the shower when necessary.
RJKSr is offline   Reply With Quote
Old 01-13-2020, 05:06 PM   #31
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
We squeegee after use and call it good . We also use a Mr.Clean sponge at the end of the trip.
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 01-14-2020, 10:54 AM   #32
vgh
2017 25' Flying Cloud
Collierville , Tennessee
Shower Care
My husband and I use the Norwex cloths to shower with. So there is no soap residue in the shower. We wipe the shower down after both of us have showered with a Norwex cleaning cloth. Our Air stream is three years old and the shower is like new.... no chemicals.
vgh is offline   Reply With Quote
What do you use to clean your Airstream? Johnbeckner Cleaning, Stripping & Polishing 50 11-05-2019 05:56 PM
How often do you use your shower | Poll Janet H General Repair Forum 96 02-13-2016 08:18 AM
Do you use your shower? Scott J-24 Sinks, Showers & Toilets 117 01-16-2012 05:43 PM
What Do You use To Clean Your AS ? nm1oqrz Cleaning, Stripping & Polishing 26 09-21-2011 01:56 PM
