Old 09-19-2006, 01:23 PM   #1
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
What brand toilet to buy?
I've looking around the $150-200 range
I see the Aqua magic V $130
Sealand lite $142
Thetford Bravura $150
The Bravura looks like the nicest outside design any thoughts?
'77 Sovereign Intl 31' CB
Old 09-19-2006, 08:59 PM   #2
1960 24' Tradewind
santa barbara , California
Hello lipets, the sealand travler lite is the one we purchased .great quality
china bowl ,works great. I think any of the china bowl toilets are better than the plastic models for sure.
Scott of scottanlily
scottanlily is offline   Reply With Quote
Old 09-19-2006, 10:42 PM   #3
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
OlyPen , Washington
Images: 90
Buy one that fits the space. We also bought a sealand traveler lite but that's becasue it was the only one that would fit in the tight space. The pot has been great and it was money well spent. Sealand makes a larger model - if you have ample room.
By the way.... sealand is owned by Dometic and they have started branding them as Dometic toilets.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 09-19-2006, 10:49 PM   #4
New Borockton , Alabama
Images: 21
Sealand had always been a high end unit and is well regarded in the marine circles as well. Fit is important and it needs to fit comfortably in/on your compartment.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
Old 09-20-2006, 07:09 AM   #5
Images: 59
If you have the room, put in a Sealand 500 series. They sell for $200. They have a very nicely sized accomodation.
Here's a size comparison between the Sealand 511+ and my original 1959 model.
Old 09-20-2006, 07:17 AM   #6
Very american 4 a french
brunoffrance's Avatar
1971 27' Overlander
DUNKERQUE / FRANCE , Nord
Images: 68
I ve replaced my genuine toilet on my 1971 overlander 27' this year, with the Aquamagic thedford . it's the high model and the Airstream cover don't fit well, above it; The fixing screws are not in the same places but you can moove them correctly. Finally it's a good replacement part.
Bruno.
My blog:The american dream in FRANCE:
My pictures in high quality: Pictures on FLICKR:
My videos are on YOU TUBE
My AIRSTREAMLIFE ning
brunoffrance is offline   Reply With Quote
Old 09-20-2006, 08:57 AM   #7
McLogger's Avatar
Columbia , South Carolina
I just replaced mine with a new Auqua Magic. Yes the holes probably won't match up on any of the newer ones. Our flange going into the tank was rusted bad and since the new one didn't fit anyway my father and I bought a new flang at lowes made a few adjustments and we now have a new toilet. I would be happy to help if you need more info.
Happy Camping
McLogger, AIR # 16452
McLogger is offline   Reply With Quote
Old 09-21-2006, 05:47 AM   #8
2007 25' International CCD
Arlington , Virginia
Do replacement toilets come in both ROUND and OVAL seating like most home bathrooms do?
Streamer1 is offline   Reply With Quote
Old 09-21-2006, 06:10 AM   #9
Road Ruler's Avatar
Images: 38
Mark.. Tne pictures are worth a 1,000 words. thnxs
Old 09-21-2006, 08:01 AM   #10
Janet H's Avatar
1964 26' Overlander
OlyPen , Washington
Images: 90
Check out the PPL website. They have spec sheets for most models avaialble online.
If possible - get a toilet that takes a standard household seat. Our Sealand came with a cheesey unstable seat and we swapped it out for coated wood one that we picked up at walmart. Made all the differenece in the world - but added a coulpe of pounds to the trailer. The cheesey one was thin plastic and really light.
Old 09-21-2006, 08:15 AM   #11
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
We're getting a new toilet installed this weekend. I don't even know what brand, Darol picked it up for his GT project and said he'd stick it in mine if I wanted, since the GT is far from needing a toilet yet. I'll report back after he installs it.
My main concern was water leaks on my current one (which is not the original) and the height. He's installing a shorter toilet, which I think will work better with our above-the-floor black tank.
Stephanie
Old 09-24-2006, 03:48 PM   #12
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
Got my new toilet
Well, I got my new toilet, and it's a HUGE improvement over the old one. This one is a Sealand short model, ceramic, pretty much looks about the same size as a regular houshold toilet, in fact I think the seat area is bigger than the one that was in there. Fit in with no problems, in fact Darol found a broken bolt and ill fitted gasket on the old one which had made it a little wobbly. This one is mounted solid, plus the bowl holds water, which I wouldn't be so excited about except it was always a surprise if the old one was going to be working or not
Stephanie
Old 09-24-2006, 08:07 PM   #13
Sugarfoot's Avatar
1958 22' Flying Cloud
1956 30' Sovereign of the Road
1963 16' Bambi
Southeastern Area , Tennessee
Originally Posted by Stefrobrts
Well, I got my new toilet, and it's a HUGE improvement over the old one. This one is a Sealand short model, ceramic, pretty much looks about the same size as a regular houshold toilet, in fact I think the seat area is bigger than the one that was in there. . . .
Looks great, Stephanie. Do you know if yours is a Sealand 500 series (Traveler) or 100 series (Traveler Lite)? I'm working towards a replacement right now too and have pretty much decided on Sealand low profile.
Traveling With Elvis
life with a 1956 Sovereign of the Road
Sugarfoot is offline   Reply With Quote
Old 09-25-2006, 11:57 PM   #14
1960 24' Tradewind
Sugarfoot ,the sealand travler lite is the one we have in our 60 trdwnd .
A great replacement , I think its the 110 model ,well its the short style .
looks like stefrobrts .I was able to use a standard home type cover .its
kind of a coral color to match the tub and sink .The cover does hit the vacuum breaker at the top rear some ,but easily corrected .just makes it
alot better than just the plain look .
Scott
Old 09-26-2006, 04:17 AM   #15
Auretrvr's Avatar
Iowa City , Iowa
What about the weight?
A china loo would be great, but what about the difference in weight? (Ahhh, poetry...)
We just got an '83 310 Moho and I really want to replace the old toilet, but we don't want to add a heavy unit.
The old one holds water and works fine. It is, however, dull, so the water doesn't shed away like it did in the Thetford in our popup. If there is a way to polish it to bring it back to the smooth surface it was, I would. Anyone tried that.
PS: We are on the way home with our baby and like two little kids! Will post all about it soon!
Airstream OCD...there is no cure!
1983 Classic 310 Motorhome.
AIR 15765
Auretrvr is offline   Reply With Quote
Old 09-26-2006, 11:24 PM   #16
1960 24' Tradewind
Hello Auretrvr,
the sealands and the other styles of china toilets are much lighter by far
than any household toilets .the sealand 110 is pretty light and the original
was porcelin so not much difference there. Its nicer I think than any plastic toilet .
Old 09-27-2006, 07:58 AM   #17
Images: 59
Don't know the weight of the original in your MH. The Sealand low profile unit (pictured in my post above) weighs 36.1 lb. The other toilet shown weighs 26.9 lbs.
MH pre-buy suggestions jkleven Airstream Motorhome Forums 13 03-27-2006 07:21 AM
Questions about the 2003 International. Would you buy again/fair price. Debbie 2002 - 2005 International 29 11-07-2002 04:11 PM
newbie looking to buy Oak All Argosy Trailers 13 10-11-2002 10:17 PM
where to buy new aluminum lp tanks.. JohnGalt48 LP Gas, Piping, Tanks & Regulators 3 09-14-2002 10:36 PM
1980 Airstream Land Yacht - Should we buy? cbird01 Airstream Motorhome Forums 0 08-03-2002 09:06 AM
