Old 11-24-2010, 07:28 PM   #1
1970 23' Safari
Sacramento , California
wet bath removal
Hi All
I have a corner wet-bath (toilet and shower) that is in two halves. I removed the top half and I am left with the bottom half still in the trailer. It appears that the toilet ring and the shower drain are the only way that the unit is held in place. I removed a piece of alum sheeting on the underside of the back corner revealing some black drainage pipes, joints and the black water tank discharge valve.
I have two questions - one am I correct about how the unit is attached? and two - how do I access the underside of the shower drain so that I can remove the bottom half? The drain is approximately 12" from the side of the trailer and 33" from the rear.
Happy Thanksgiving.
Mark
M1970 is offline   Reply With Quote
Old 11-24-2010, 09:27 PM   #2
Maniacal Engineer
barts's Avatar
Menlo Park , California
Happy Thanksgiving.
Mark
The drain will unscrew from the piping, using a cylinder w/ a cross cut into it that fits into the drain. However, on mine the corroded cross in the drain broke... since I needed to do floor repairs (and as it turned out, fix rear end separation), I dropped the belly pan in the back. I'm completely re-building the bathroom, so I ended up just cutting the piping loose from underneath. I re-plumbed things again w/ ABS, and have a much larger and studier drain ready to go in once I get the shower finished.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 11-27-2010, 12:08 PM   #3
1970 23' Safari
Hi Bart
Thanks, I got it out without damaging anything. I used a pair of needle nose pliers. I did discover some dry rot under the black water tank. Is this what you are dealing with?
Mark
Old 11-28-2010, 09:39 PM   #4
Maniacal Engineer
barts's Avatar
Hi Bart
Mark
Actually, the tank area was fine; the rear plywood was rotted as water has worked it's way underneath the plywood. I ended up replacing about the last foot of plywood....
- Bart
Bart Smaalders
Menlo Park, CA
Old 11-29-2010, 07:09 AM   #5
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
Note for the future: Lowe's or HD sells a "drain key" used for drain removal. This worked great for me. About $12.
DanB
________________________________
Proud Member of the Wally Byam Airstream Club #24260
www.campnova.com
The “Ohio Airstreamer -- Informal forum for weekend camping” thread.
DanB is offline   Reply With Quote
What size is your wet bath? muddy_hollow 2005 and newer - Bambi all models 3 05-27-2008 06:29 PM
Has anyone ever converted a regular rear bath to a wet bath? tvadman1963 Sinks, Showers & Toilets 2 12-29-2006 11:15 AM
Wet Bath jcferguson Sinks, Showers & Toilets 7 03-02-2006 01:19 PM
Wet Bath in 72 Tradewind Lee Pace Sinks, Showers & Toilets 3 11-01-2005 11:14 AM
wet bath - what years? AV8 1970-79 Tradewind 4 01-01-2004 07:16 PM
