Old 11-29-2010, 04:42 PM   #1
1989 34' Excella
Holly , Michigan
Wax ring for toilet seal?
Is a wax ring acceptable to reinstall the toilet? The seal I took out was some type of soft rubber/foamy material.
cathy624 is offline   Reply With Quote
Old 11-29-2010, 04:53 PM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
You are better off using a new foam seal,you should be able to get one at any RV supply.
Dave
easyride is offline   Reply With Quote
Old 11-29-2010, 06:39 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
If you have an RV-model toilet, then a wax ring is a big NO NO! Every manufacturer of RV toilets have model-specific foam seals that should be used with that toilet. Wax rings are fine for a house, but your house won't bouncing down the road at 65mph, unless of course you liver in Kansas during a tornado.
Old 11-30-2010, 07:30 AM   #4
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Don't for get the heat, wax melts where the foam doesn't.
Need new seal if toilet pulled? Becky B. Sinks, Showers & Toilets 16 07-25-2007 07:52 PM
Wax ring???? retrocats Sinks, Showers & Toilets 20 04-24-2007 08:02 PM
toilet seal cookeville34 Sinks, Showers & Toilets 1 02-07-2007 08:00 PM
Post polishing seal or wax? Jabba Cleaning, Stripping & Polishing 20 09-03-2004 03:30 PM
Toilet Bowl Seal Question? JoeW Sinks, Showers & Toilets 1 10-09-2003 10:34 PM
