Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 06-30-2006, 08:51 AM   #1
tmeagle1's Avatar
Profile:  1985 34' Limited
Croswell , Michigan
Water in Shower is a fine drizzle
I own a 34' 1985 Limited with queen bed in back. The shower began running fine and then went to a fine drizzle, like I lost water pressure. The kitchen, bathroom, toilet, etc, has fine water pressure, warm and cold. The shower on the other hand does not. I'm using my holding tank water, not a direct water source from hose. Can anyone help me figure this out. Is there a valve or something that may be turned off half way or something? Please advise.
Thanks.
Tim Eagle
tmeagle1 is offline   Reply With Quote
Old 06-30-2006, 09:12 AM   #2
tinman7's Avatar
Profile:  1976 27' Overlander
Arlington , Massachusetts
Images: 13
Tim, May be some dirt in your shower head. Remove it and backflush.
tinman7 is offline   Reply With Quote
Old 06-30-2006, 09:16 AM   #3
genearnold's Avatar
Profile:  1992 34' Limited
Boise , Idaho
I haven't had problems with my shower pressure (however, I seldom use it) but I have had problems with the bathroom sink. It turned out to be a plugged screen in the faucet. I don't know if there is a screen in the shower faucet but the shower head could be plugged. I'd take off the head and see if the pressure is there. If it is OK without the head you might have to replace the shower head since some of them can't be dis-assembled.
Gene
'92 Limited 34ft; '96 Dodge Cummins 4X2, 5speed
genearnold is offline   Reply With Quote
Old 06-30-2006, 09:42 AM   #4
Frank S
Profile:  1973 27' Overlander
peoria , Illinois
Hi tmeagle1--If your shower head is clogged with calcium buildup, soak it in CLR, or Limeaway (available at hardware, grocery, and big box home stores). May also need a little tooth pick poking to finish the job.--Frank S
Frank S is offline   Reply With Quote
Old 06-30-2006, 10:16 AM   #5
tmeagle1's Avatar
Croswell , Michigan
Water Pressure
Thanks, I will try all of your advise this weekend. We are using the airstream to live on weekends at a summer home and for camping. I appreciate all the fast responses. Thanks again.
Tim Eagle
http://www.croswellmich.com (portal of horror)
Old 07-01-2006, 12:46 AM   #6
Profile:  1960 24' Tradewind
santa barbara , California
Agree that CLR works great ,it totally cleaned and renewed my original
shower head in my 60 trdwnd .I really like the hot shower !! ,Its only 5 min
but really effective in freshining up.
Scott
scottanlily is offline   Reply With Quote
Old 07-01-2006, 09:57 AM   #7
Nye Thatcher's Avatar
Profile:
Tim. I soak my shower head in vinigar about once a year and clean the filter, which is located at the end of the hose where it attatches to the shower head. Good luck
Nye
Nye Thatcher is offline   Reply With Quote
Old 07-01-2006, 01:13 PM   #8
Chaplain Kent's Avatar
Profile:  Wauwatosa , Wisconsin
Tim,
If you have cleaned out the shower head and still find no pressure try removing the valve at the base of your shower hose. This valve is installed to prevent the backflow of water through your shower hose, such if you accidentally drop it into the toilet. This is a nice feature for a home plumbing system but really not needed in an RV and can become plugged.
Chaplain Kent
WBCCI #7235 - Former VAC
1982 280 Turbo Diesel Motor Home (Chummy)
http://goodsamclub.mytripjournal.com/Chummy
Chaplain Kent is offline   Reply With Quote
Old 07-01-2006, 01:42 PM   #9
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
and the water saver button on the shower head isn't halfway off?
john
you call them ferrets, i call them weasels.
Old 07-02-2006, 05:37 PM   #10
tmeagle1's Avatar
Croswell , Michigan
It was the obvious
There was a water saver button on it, it was turned off. Thank everyone for posting here. I guess I'm still getting used to this year airstream. My 1972 was quite different, plus three feet shorter, this airstream has all the modern conveniences. Thanks again to everyone.
Tim Eagle
Old 07-02-2006, 05:42 PM   #11
john hd's Avatar
madison , Wisconsin
Images: 40
hey ya gotta love the cheap fixes!
john
Old 07-03-2006, 10:10 AM   #12
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Water heater flush
One more tidbit of info. It is a good idea to buy one of those water wands they sell at Camping World. It looks like a small rigid plastic hose with an angle on the end and the other side connects you your water hose. After a few trips, drain the water tank and then stick the wand into the opening. Turn the hose on and you will be surprised at all the loose scale that comes out of the opening. This is the kind of stuff that goes through your system and plugs the faucet screens up. It sure has worked for me.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 07-03-2006, 11:08 AM   #13
1 Rivet Short
Profile:  1989 25' Excella
By The Bay , Rhode Island
I just installed on of the "Oxygenator" shower heads from camping world-very pleased. Shower is much better now!
BillTex is offline   Reply With Quote
Old 07-03-2006, 11:34 AM   #14
Cartoon Character
Porky Pig's Avatar
Profile:  2004 34' Classic
On The Road , U.S.A.
Originally Posted by BillTex
I just installed on of the "Oxygenator" ...
Wasn't that a Schwarzenegger movie? You know, the one where he sucks all the air out of California.
Porky
TrailerGypsies.com
WBCCI #3405 — Escapees #80360
I live the life I love and I love the life I live.
-- Willie Dixon
Porky Pig is offline   Reply With Quote
Pingbacks are On
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
Water Heater Woes airstreamcaravel Water Heaters, Filters & Pumps 3 09-07-2005 09:18 PM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 12:03 PM
Water leaks Craig Fresh Water Systems 3 08-08-2002 01:44 PM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 10:28 AM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
Search Engine Friendly URLs by vBSEO 3.2.0 RC8
