Old 09-15-2015, 05:39 PM   #1
LifeIsShort
Tsmith.wp's Avatar
2013 22' FB Sport
Winter Park , Colorado
Water seeping from under wall
On the last day of my trip, I decided to start the winterizing process while I had full hookups and a level pad. It is already in the 30s in the morning at home.
Following AS instructions, I drained the forward line drains after lowering the hitch, to tilt the unit forward. As I went inside to open the valves, I noticed water seeping from underneath the shower area into the living area. This is a 2013 22FB. I am imagining there is pooled water from a loose fitting at the shower drain.
I tried to see something from the shower controls access panel, but it is too tight. I tried removing the wall panel between the shower and living area, but it is somehow attached beyond the four visible screws. I tried removing the panel below the shower door, but it won't budge after removing its two screws.
Other than breaking something, how does one access the area beneath the shower pan? They sure do build these with tight access to the important stuff.
Hope someone can help with this.
Thanks.
Tim
Tsmith.wp is offline   Reply With Quote
seeping type leak on fresh water tank '77 Overlander vcsnover Fresh Water Systems 6 04-06-2015 07:09 PM
Water seeping in under the the rear valontjej Leaks - Weatherstrips, Gaskets, Caulks & Sealants 23 06-14-2013 05:27 PM
Water seeping under cabinet near refrigerator Phoebe2009 Fresh Water Systems 10 01-25-2012 04:58 PM
Wall-to-wall carpet alternative mcneon Upholstery, Blinds, Walls & Interior Finishes 9 11-20-2008 01:41 PM
water seeping in compartment door Mike Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 10-23-2002 12:14 PM
