Old 09-15-2015, 10:05 AM   #1
bhooves
2013 27' Flying Cloud
Livingston , Texas
Water Pressure: Shore pressure high, All pressure in trailer low....
2013 Flying Cloud FB 27', The shore water pressure is satisfactory, but our pressure in shower, both faucets, and toilet very low. Any suggestions for clearing water line inlet, or whatever else may be the problem? We're full timers and this issue is very annoying.
bhooves is offline   Reply With Quote
Old 09-15-2015, 01:26 PM   #2
2016 30' Flying Cloud
Oviedo , Florida
I'm assuming you have tried the pump with internal tank, and everything seems OK? Are you using an external water filter?
Keith & Barb
2016 Ram 2500 diesel
Southeastern Camping Unit, WBCCI #1675
khollister is offline   Reply With Quote
Old 09-15-2015, 01:49 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you have tries the pump and have OK pressure then I would look at the pressure regulator at the city connection on the trailer. That regulator should be factory set to about 45 lbs. But like everything else made in China it may not.
Try the pump if you have not and post the reaction.
2004 Excursion 4x4
Old 09-15-2015, 10:21 PM   #4
bhooves
Livingston , Texas
Thank you for the reply. I replaced the water filter, and checked the water pressure from the hose. Very good pressure, and easily filled the fresh water tank quickly. I also used the pump to supplement the water pressure and it worked much better. Where is the pressure regulater that was factory installed located? Also, I had a technician from he factory show me how to clean the water heater. It was a demonstration, not a complete cleaning of the water heater. I think. Could dislodged lime, etc. from the water heater gotten into the cold water line as well as just the hot water line. I presume that the pressure regulator could have from China could be the culprit, so how do I go about changing it? Thank you very much for the reply. I didn't know about the factory installed regulator so you have certainly helped me take a giant step toward solving this mystery.
Old 09-16-2015, 11:42 AM   #5
shadedsilver
2014 27' FB International
Bisbee , Arizona
There is probably a small filter screen on the water inlet that is clogged. It pulls out and is easily cleaned with a wire brush. If you use an inline filter you might check that.
shadedsilver is offline   Reply With Quote
Old 09-16-2015, 01:05 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
clean screen filters...in emergency.. replace when able..
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-17-2015, 08:38 PM   #7
1975 31' Sovereign
West Liberty , Kentucky
I had a similar problem. After checking everything I could think of, I asked a fellow AS owner who said to check the screens in each faucet aerator. All were plugged up. Cleaned them and everything was fine.
Air4563 is offline   Reply With Quote
Old 10-16-2016, 03:09 PM   #8
2015 25' Flying Cloud
Blenheim Ontario , Ontario
My FC manual says that the city regulator is set at 65 psi;
and the water pump set at 55.
"Trailer Trash living in a Tin Can shed."
"If it moves, oil it. If it doesn't move, paint it. If it talks back, salute it."
Old Air Force Sgt.
"Look after your equipment, it will look after you."
MelGoddard is offline   Reply With Quote
Old 10-16-2016, 03:14 PM   #9
And just HOW does one clean the screen in the faucet aerators?
After reading your 'thread', I went out to check mine, (30' FC.) and I could see no way to remove the screens. They are green plastic 'thingies' in the 'bell mouth' of the faucet, and unable to grab, even with a soft jaw pliers.
Old 10-16-2016, 03:22 PM   #10
HowieE's Avatar
Images: 12
Back to the problem. I using the pump gives you god flow the problem is not the screens at the faucets. Have you removed the hose at the city connection and looked at the screen just inside the hose connection. If clogged that will reduce flow.
Another test is while hooked to city water turn on any faucet. Is there a noticeable surge of water flow that quickly drops off. That would indicate the pressure regulator is supplying pressure to the system but the flow is restricted. If the hose when disconnected from the trailer flow well again I would look at the city connection screen.
2004 Excursion 4x4
AC High/Low pressure switch bypass Vycan Classic Motorhomes 1 01-12-2015 04:32 PM
Gas Prices for 2011 - How high is too high to tow? Kosm1o On The Road... 77 01-02-2011 09:48 PM
High Pressure vs. Low pressure Appliances emenriquez General Appliance Topics 2 06-15-2009 01:04 AM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
