Old 07-25-2011, 04:26 AM   #1
xxx , xxxx
Water Everywhere!
Replumbed my 71 overlander and ran into a snag. Water is passing through my shoer faucet and feeding the hot water line. I replaced the cartridge thinking it would help, but it did nothing. Am I missing something?
travis0123 is offline   Reply With Quote
Old 07-25-2011, 06:13 AM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
If it is a single handle faucet,the handle must be pushed all the way to the right (cold),or it will cross over. Dave
easyride is offline   Reply With Quote
Old 07-25-2011, 07:21 AM   #3
xxx , xxxx
It is a single lever. The knob has no stop when you turn it. should I have a check valve somewhere? It's backfeeding full pressure cold to the hotwater tank.
Old 07-25-2011, 07:39 AM   #4
1977 Argosy 24
Milltown , Wisconsin
Put a one way valve/backflow valve in the hot water line that feeds the shower.
ventport is offline   Reply With Quote
Old 07-25-2011, 08:17 AM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
The faucet should only allow bypass when it is in the open position. If the hot water tank is empty or has some other way for relieving pressure in the line , and if you have the shower heads' valve is closed, that flow is normal untill the tank gets full.
While the water is on and flowing push the shower knob in. If pushing in does not work, turn the knob slowly till you hear the flow stop. I think one of these methods should cut the flow off completely.
I think something is wrong if the knob does not have a stop! What brand of faucet is it?
A W Warn is online now   Reply With Quote
Old 07-25-2011, 09:00 AM   #6
richinny's Avatar
2011 34' Classic
i seem to remember reading something about this happening if the cartridge is installed backwards. i'll try to find the thread.
Ricky
Old 07-25-2011, 09:09 AM   #7
richinny's Avatar
2011 34' Classic
not the post i remember but i think if the valve is installed 180 degrees off you'll get the problem you have mentioned.
http://www.airforums.com/forums/f163...ower-4454.html
Ricky
Old 07-25-2011, 10:05 AM   #8
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Yes there is an up and down on the valves. There should be a little notch on one side of where you connect the handle. This notch goes down (most of the time) If it is in upside down water will pass through.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-26-2011, 04:37 AM   #9
xxx , xxxx
Thanks for the help everyone. I replaced the cartridge in the faucet with a Moen 1200(same as orig). I noticed the problem of the backfeeding only because I left the "hot water out "line off the tank to test for cold water leaks. What I observed was a majestic fountain of cold water rising from the open hw line.
As far as the orientation of the cartridge in the housing-I installed it up,down,sideways, ect with no change. I'll keep messing with it.
Noobie black water question pappy19 Waste Systems, Tanks & Totes 9 05-25-2011 09:52 PM
Fresh Water Tank Size and Gauges ednspace Fresh Water Systems 4 05-23-2011 08:19 PM
Water Heater Calcium Deposits -- What to do? Wilmington Water Heaters, Filters & Pumps 7 05-18-2011 03:11 PM
atwood water being fitted to a 1960 Overlander Lothlorian Water Heaters, Filters & Pumps 10 01-01-2011 05:42 PM
