Old 06-25-2006, 12:53 PM   #1
1964 22' Safari
Scottsdale , Arizona
Water Closet
When the toilet flush peddle is pushed to the floor and released a small amount still runs after the flush. Is there an adjustment?
Water leaks out of the waste holding tank around the push pull drain release.
What is this part called? Can it be repaired?
If you have seen the movie Cars my 64 safari would be TOW MATER
Chip
achip is offline   Reply With Quote
Old 06-25-2006, 07:07 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
It should run on for a short while to add water to the bowl again, in my case about 3/4 in.
If it runs on longer and does not stop, then you might have to take apart the valve mechanism and have a look-see. Might need rebuilding.
Chip
The part is called a dump valve. If it is original, then it might be a Thetford valve. You might check the seat of the sliding blade, and see if there's toilet paper stuck in it, preventing it to seal completely. Not a fun job.
Uwe
www.area63productions.com
Old 06-25-2006, 11:14 PM   #3
1960 24' Tradewind
santa barbara , California
Hey achip ,
Off topic ,sorry but the cars movie was well done .Has the route 66 theme to
it and all ,the hudson hornet was a real contender in its day ,won many races.
Scott
Uwes idea is the best place to begin on the throne trouble
scottanlily is offline   Reply With Quote
Old 06-25-2006, 11:18 PM   #4
CaddyGrn's Avatar
1963 16' Bambi
1962 22' Safari
Yreka , California
Cars was awesome!
Chip
The movie Cars was awesome! And, Tow Mater was very, very cool! I kept looking for an airstream like trailer in the "audience" in the film, but alas I didn't see one.... but a whole lot of SOB's.
Mrs. NorCal Bambi
CaddyGrn is offline   Reply With Quote
Water problems Dbraw Fresh Water Systems 14 10-03-2009 02:15 AM
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 12:03 PM
Water Pump Dbraw Water Heaters, Filters & Pumps 6 06-15-2002 10:35 AM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 10:28 AM
