Old 08-31-2006, 08:29 AM   #1
near ichnetucknee springs
charlie tuna's Avatar
1978 31' Sovereign
davie , Florida
using fiberglass to reinforce shower corner
hi all,
i am considering repairing the corner of my rear bathroom 1978 AS. the corner that backs up to the closet is cracked and needs to be re-inforced and sealed. after the fiberglass clothe and resin i will sand it smooth and paint the entire enclosure with a marine epoxy paint. has anyone tried this?
thanks, tuna
charlie tuna is offline   Reply With Quote
Old 08-31-2006, 09:30 AM   #2
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Originally Posted by charlie tuna
hi all,
thanks, tuna
I have done it on several boats. You will need to grind the area to get a good bind. The last fiberglass cloth should be very fine and you will more than likely have to use bondo to get a smooth finish. I would suggest Interlux Brightside Paint for your top coat. I am currenlty repairing my sailboat after Katrina and I use epoxy resin as opposed to fiberglass just works better.
Good Luck Jim
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 08-31-2006, 09:31 AM   #3
airstream4's Avatar
1997 34' Limited
1963 22' Safari
Troy , Michigan
I fiberglassed a crack on my sink in a 78 sovereign on the back side and repainted with marine paint, painted shower and tub at same time. Cracked reappeared two years later and I epoxied on surface and repainted has held up good for three years! I'd do back side if possible, I replaced shower wall (closet wall) with marlite and had to remove tub and shower wall and it was a major project! Surface repair would be my choice unless that portion can be removed easily.
Paul
Paul
Troy, MI
1963 22'Safari
1997 34' Classic FK
airstream4 is offline   Reply With Quote
Old 08-31-2006, 10:21 AM   #4
1978 31' Sovereign
davie , Florida
yes, i plan on installing a brace on the backside--inside the closet -- to the outside wall. then screwing the shower's back wall to that and then grinding down the repair surface - then apply two or three layers of fine glass mat to the area -- each being smaller than the last. then applying enough resin to get a smooth surface or near smooth. then sand with light paper till smooth. and i'll take your advice on the paint. thanks, tuna
1985 Excella shower vent fan gimmejul Roof Vents, Skylights & Fans 8 05-01-2003 07:56 PM
Shower head problems Pahaska Our Community 25 08-26-2002 10:43 AM
Shower head Pahaska 2002 - 2005 International 0 08-24-2002 04:13 PM
Shower head Pahaska 2002 - 2005 International 0 08-24-2002 04:12 PM
Shower curtain Zed2 Upholstery, Blinds, Walls & Interior Finishes 1 06-24-2002 09:03 PM
