Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 10-22-2009, 04:15 PM   #1
WILDRTEXAS's Avatar
Profile:  1970 27' Overlander
ARLINGTON , TEXAS
Airstream Registry
Send a message via Skype™ to WILDRTEXAS
Upgrading to Pex...Any reason I cant move
the Hot/Cold/Drain valves up above the subfloor for easier access?
He is your friend, your partner, your defender, your dog. You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion...
Taylor 1/20/96 - 11/28/08
WILDRTEXAS is offline   Reply With Quote
Old 10-22-2009, 05:04 PM   #2
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 41
No reason at all, unless it's a tank drain valve, in which case it needs to be slightly below the tank level.
Uwe
www.area63productions.com
Old 10-22-2009, 05:23 PM   #3
Profile:  1974 31' Sovereign
beautiful downtown Aurora , Ontario
Airstream Registry
Send a message via ICQ to Aage
Isn't that gonna eat space needlessy for something you'll only use a couple times a year...?
It's a combination of Alzheimers and Deja Vu - I keep thinking I forgot this before.
Old 10-22-2009, 05:38 PM   #4
WILDRTEXAS's Avatar
ARLINGTON , TEXAS
Airstream Registry
Really hate that creepy hole... seems like easy access to rodents, snakes and spiders and other slithery things. Any ideas??? The 1st valve goes to the drain, 2 hot water 3 cold water.
Old 10-22-2009, 05:40 PM   #5
WILDRTEXAS's Avatar
ARLINGTON , TEXAS
Airstream Registry
Oh, can I replace the current valves with a pex manifold?
Old 10-22-2009, 05:44 PM   #6
uwe
418
uwe's Avatar
Images: 41
No need for a manifold, you can use the Flair-it drain valves.
Uwe
Old 10-23-2009, 09:24 AM   #7
WILDRTEXAS's Avatar
ARLINGTON , TEXAS
Airstream Registry
Uwe, . Flair-it drain valves Im am unfamilar with. Pic? Where to buy? Thanks for the tip.
Old 10-23-2009, 09:59 AM   #8
vinstream's Avatar
Profile:  1962 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
http://http://www.lowes.com/lowes/lk...PK1&lpage=none
I like these Pex valves the best, they work well in any area, take up the least amount of space and are priced right!
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
vinstream is offline   Reply With Quote
Old 10-23-2009, 10:04 AM   #9
vinstream's Avatar
http://www.airforums.com/forums/atta...1&d=1256313850
Sorry link was not working.....
www.VINSTREAM.com
WBCCI # 1962
Old 10-23-2009, 12:18 PM   #10
uwe
418
uwe's Avatar
Images: 41
I use these, most of the time. I never had a leak once, and no special tooling is required.
I am not affiliated with this parts supplier, I merely buy from them sometimes.
- RV PARTS OUTLET
Uwe
Old 10-23-2009, 12:25 PM   #11
Airstream Registry
I really love the Flair-It PEX fittings, I used them after reading through Uwe's thread and seeing how highly he thought of them. I've had some minor leaking issues with a couple of other brand of PEX fittings I used because I ran out of Flair-Its, but none at all with the Flair-Its themselves.
utee94 is online now   Reply With Quote
Old 10-23-2009, 12:30 PM   #12
uwe
418
uwe's Avatar
Images: 41
The only issue ever was a drip where a flair it adaptor was threaded into a fpt outlet of a water heater. It takes more sealer tape than one would think to make this work without a failure. So, the plastic to metal connection needs a little extra consideration.
Uwe
Old 10-23-2009, 01:11 PM   #13
Airstream Registry
Well, it's your trailer, Wildr. But it looks in the photo that you have the darkness licked. Mebbe just a small light in there?
Yes, they're all drains. In the winter (something you may not experience much of where you are!) us Northerners actually have to take the water out of the pipes, or they will certain sure freeze and break. Those other two taps are to drain the water in the pipes leading to the tap set on the kitchen sink.
They all are "billed" as "lowest point" for drain purposes, so you had best take a look at where you are going to reposition them to, just in case you ever decide to come up to this frozen part of the world in winter...
Old 10-23-2009, 05:30 PM   #14
WILDRTEXAS's Avatar
ARLINGTON , TEXAS
Airstream Registry
- RV PARTS OUTLET
FANTASTIC!! Just what I needed...a visual and a supplier Thanks a bunch!
just another reason to 'stream finalcutjoe Our Community 11 12-13-2009 07:28 PM
What is the reason for rally locations? longdog Forum Rallies & Meet Ups 22 05-03-2009 08:10 PM
Reason the WH is on the RS tmcdougald Water Heaters, Filters & Pumps 3 08-09-2005 08:37 PM
Trying to Reason with the Hurricaine Season hhuber Our Community 8 09-24-2004 08:36 AM
Help and the voice of reason tamis Buyer Guidelines 4 10-20-2003 07:36 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
