Old 03-17-2009, 10:29 PM   #1
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
Upgrade Thetford Aqua Magic V Toilet ??
I have a Thetford Aqua Magic V toilet with a plastic bowel in our 25' FB 2007 Safari. The drain blade in the current unit has developed raised spots and is absorbing the color from the blue head chemical. I want to replace it with a Thetford china bowel toilet and would like to know if anyone has undertaken that project and what model they were able to fit in the bathroom without any modifications?
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 03-17-2009, 10:54 PM   #2
1994 30' Excella
Mississauga , Ontario
Sounds like the blue chemical is the culprit for the bumps. Water and sewage wouldn't cause that to happen. Don't know about the toilet swap but suggest you be careful that the same doesn't happen with the new toilet.
Al
Old 03-18-2009, 12:35 AM   #3
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
We used a Style china toilet to replace our plastic-bowl toilet.
Old 03-18-2009, 09:47 AM   #4
Excella3287's Avatar
China bowl
Hey Terry nice to hear from you. I would also like the china. Is there a part # and manufactor? thanks
Excella3287 is offline   Reply With Quote
Old 03-18-2009, 10:05 AM   #5
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I used a Sealand Traveler lite in a 1981 trailer. It has a china bowl and seems to work great. The install was a piece of cake.
Vintage Trailer Supply - Vintage travel trailer parts and supplies!
crispyboy is offline   Reply With Quote
Old 03-18-2009, 11:21 AM   #6
1986 31' Sovereign
Miami , Florida
Ditto here --- Sealand Traveler Lite. Easy install. Wish I'd done it much earlier...
mike
Old 03-18-2009, 12:09 PM   #7
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
I also used a sealand.
BUT, as someone else alluded, that may not keep the plastic parts in the valve assy from discoloring. With that said, I do like the china bowl much better.
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 03-18-2009, 01:21 PM   #8
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Do the newer Airstreams have a 2 bolt or 4 bolt and does one need the adapter to make it a 4 bolt to install this?
I found this place that had it for a bit less through the 20th of this month:
http://www.pplmotorhomes.com/parts/rv-toilets-tanks/sealand-traveler.htm
Old 03-18-2009, 04:58 PM   #9
1998 28' Excella
Dolores , Colorado
We installed a floating floor in our bath/kitchen area las tyear and we replaced the stool with a Aqua Magic High Profile (Bone) unit from Camping World. It went in very easily and all I needed was a new ring for it. Had to route the water to it a little differently buty we are quite pleased with it. They have low profile units also.
4CU/CAC
WBCCI # 10105
AIR # 28748
dogpound is offline   Reply With Quote
Old 03-18-2009, 08:05 PM   #10
1976 31' Sovereign
Oswego , Illinois
Smile farmer bill
I replaced the plastic thetford aqua magic with thetford aqua magic china bowl fit perfectly no mods Ido not remeber model # but purchased at camping world all replacement parts available
Old 04-14-2009, 10:10 AM   #11
2dabeach's Avatar
Update
Update: After talking to Thetford I found out that there was a clear plastic cover installed on the plastic drain blade that was installed by Thetford at the factory that was not removed by Airstream or my dealer. The raise spots was where water had gotton under the clear plastic and raised it off the surface and the blue staining was from some of the head chemical workings its way between the blade and the the clear plastic cover. The clear plastic is sticking to the plastic blade and has been very difficult to remove. Will probably leave it unless it causes a problem with the blade sealing the toilet.
Old 04-14-2009, 02:52 PM   #12
2007 25' Classic
Hydes
American RV Company has the Sealand Traveler Lite for $134.95. That's the best price I've seen
craftsman is offline   Reply With Quote
Old 04-14-2009, 03:55 PM   #13
1965 26' Overlander
1960 28' Ambassador
1975 20' Argosy 20
Upper Black Eddy , PA
Sealand Traveler Lite or 500 Plus??
What's the difference btwn the Sealand Traveler Lite and the Sealand Traveler 500 Plus (more expensive)? Is there any justification to spend more on the Traveler 500 Plus?
Kathleen
kdenault is offline   Reply With Quote
aqua magic toilet repair captmorgan Waste Systems, Tanks & Totes 8 12-30-2008 12:53 AM
1972 Thetford Aqua Magic 30 cameront120 Plumbing - Systems & Fixtures 5 05-19-2007 08:59 PM
1972 Thetford Aqua Magic 30 cameront120 Sinks, Showers & Toilets 2 04-25-2006 09:19 PM
Replacement Toilet for Thetford Aqua Magic? JeepinAudiophile Sinks, Showers & Toilets 1 09-20-2004 12:05 PM
toilet:Sealand vs Aqua Magic dogwood Sinks, Showers & Toilets 8 09-02-2004 08:46 PM
