Old 11-21-2011, 08:00 AM   #1
Jim & Mitzi's Avatar
1990 34' Excella
1990 29' Land Yacht
Americus , Also Valrico, Fl
Unwanted sewer odor
1973 IS rear bath. Too often unpleasant odor comes out of toilet when flushing. Have tested with clean water. Bowl 1/2 full, push pedal to open valve ~ 1/2 way. Before bowl is MT air ( unpleasant air ) burps up through the remaining water. Could the tank vent line be plugged? I would think water entering the tank would force the air up and out of the vent pipe ???
Jim & Mitzi is offline   Reply With Quote
Old 11-21-2011, 08:10 AM   #2
Gainesville , Florida
Are you using any additive in the toilet ? jim
Old 11-21-2011, 08:43 AM   #3
Sewer vent pipes attrack some birds.One could be in that pipe.
Check that vent, and while your at it, check the vent pipe gasket as well. You will find it more than likely badly cracked.
Old 11-22-2011, 09:03 AM   #4
1990 34' Excella
1990 29' Land Yacht
Thanx to all contributors...Will be sure pipe is not plugged or impaired and will check for gasket failure. In deeper thought its a possibility that the vent line could be plugged more or less at the tank where 38 years of "contents crust" have built up. Yes, I faithfully use a potty additive. Thanx Again Jim & Mitzi
Old 11-22-2011, 09:20 AM   #5
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 11
GEO Method
Jim & Mitzi, you probably do have a tank vent problem. Also you may want to look at the GEO Method for black tank management. Just do a google search on GEO method. I have been using this method on my AS and previous SOB's. We have never had a problem with smell or build up while using the GEO method. It involves liquid detergent, water softner, and bleach. You can also dump your tanks into septic systems using the GEO method.
Good luck.
Ridgerunner3 is offline   Reply With Quote
Sewer Hose & Coupler wlanford Waste Systems, Tanks & Totes 85 05-24-2016 08:20 PM
Sewer Light sjones Electrical - Systems, Generators, Batteries & Solar 9 09-08-2011 08:30 AM
Newbie ? Home sewer clean out Bigcgar On The Road... 15 04-30-2011 05:55 AM
sewer pipe/belly pan caulk crispyboy Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 03-21-2011 08:14 AM
Need Help with a Spare Wheel and Sewer Hose for Int'l 19'? jambie 2005 and newer - Bambi all models 4 03-07-2011 07:50 PM
