Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 04-17-2006, 05:22 PM   #1
Hawk_Man
Hawk_Man's Avatar
Profile:  1975 28' Argosy 28
Hopkinsville , Kentucky
Tub Repair
Hello All, I have a tub that came out of my 1975 Argosy, 28' that has a damaged drain hole , my son sawed of the old drain (which was rusted) and cut through a portion of the drain hole thinning it and making it out of round. I believe it to be made out of ABS plastic. I would like to get a repair recommendation on what type of repair kit or product I could use to repair the damage.
Name:	Inside Tub Drain.jpg
Name:	Outside Tub Drain.jpg
God Bless and Safe Travels
Keith
Hawk_Man is offline   Reply With Quote
Old 04-17-2006, 06:15 PM   #2
myboyburt
NEU 1VP 2008-2009
myboyburt's Avatar
Profile:  1993 25' Excella
1977 Argosy Minuet 6.0 Metre
New Boston , New Hampshire
Images: 12
Attachment 20596
Attachment 20597
Keith
Balgrn may be able to recommend a solution for you. He is out of pocket until the end of this week, but if you send him a PM he will get back to you.
Michelle & Leon
WBCCI # 7032 Region 1, New England Unit
Looking for a WBCCI Unit filled with fun loving folks to camp and travel with in the New England area? Well, you've just found it:
myboyburt is offline   Reply With Quote
Old 04-17-2006, 07:39 PM   #3
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
You MIGHT be able to make the hole round again, and use a slightly larger drain fitting without scrapping or patching the drain area.
overlander63 is online now   Reply With Quote
Old 04-17-2006, 08:07 PM   #4
Hawk_Man
Hawk_Man's Avatar
I'll take a look a larger diameter drain with a reducer tommorrow. That might be better then trying to make a patch.
Keith
Old 08-17-2006, 10:15 AM   #5
Mrcrowley
Profile:  1977 31' Sovereign
Manchester , New Hampshire
I heard you can use bondo fiberglass repair on ABS..
Keith
If that is so fill in the hole and recut it after hole is cured....The hole will be stronger also...
Mrcrowley is offline   Reply With Quote
Old 08-17-2006, 06:18 PM   #6
Mrcrowley
I had to do same thing
Used a dremel tool with metal griding bit Ill patch over hole with fiber glass repair kit and redrill hole with hole saw...
Bed Glide Repair Tamara General Interior Topics 16 08-31-2006 09:28 PM
Least expensive repair thenewkid64 General Repair Forum 2 10-03-2002 08:26 AM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 07:04 PM
airstream repair halloey General Interior Topics 3 07-27-2002 07:48 PM
Greywater drain pipe repair davidz71 Waste Systems, Tanks & Totes 4 06-04-2002 10:39 PM
