Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 04-23-2007, 09:22 AM   #1
mgann
Profile:  1961 22' Safari
Fayetteville , North Carolina
tub removal -- help!!!
Morning all, got a problem removing tub in a 61 Safari, rear bath tub on street side. After removing trim, rivets and screws, still wont budge. Trying to remove drain, the 4 cross members inside the drain broke and now it just spins. After locking p-trap from underneath and trying to unscrew the drain from above but can't get it to come out. Is there a trick to this? How do I grasp the drain to turn it? In advance, many thanks.
Max
910-977-2165
mgann is offline   Reply With Quote
Old 04-23-2007, 11:16 AM   #2
Safari Tim
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
In a word. Sawsall.
I had to cut the trap off from below. If you have the low profile p trap you want to save and resue it.
I just ran the saw directly flush with the bottom of the plywood floor and I was able to save the trap.
I've heard sometimes the tubs are glued down, mine was not.
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Old 04-23-2007, 11:19 AM   #3
geezernbabe
geezernbabe's Avatar
Profile:  1970 31' Sovereign
1970 23' Safari
Shingle Srings , California
If it has the type of drain with the cross like this + you can take a standard set of pliers and put the handles down in the drain and put a long screwdriver in the jaws to hold the drain from spinning. Then loosen the under side with large channel lock pliers. As old as it is it will probably come out in pieces. Good luck
geezernbabe is offline   Reply With Quote
Olympic rivet removal and installation PeterH-79MH Ribs, Skins & Rivets 38 08-13-2008 03:31 PM
Dent Removal uwe Ribs, Skins & Rivets 7 11-14-2004 10:15 AM
Window Removal Rob Windows & Screens 2 08-31-2002 08:49 PM
Paint Removal from side of A/S Lexxy Clearcoat, Exterior Paint & Trim 2 08-19-2002 08:03 AM
Wardrobe Removal ??? 54FlyingCloud General Interior Topics 1 07-25-2002 03:22 PM
