Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 12-17-2005, 08:17 AM   #1
niftypkg's Avatar
Profile:  1971 27' Overlander
Cornville , Arizona
Thumbs down Tub Faucet Drips
Tub faucet ( fixture) drips. How does one replace the '0' rings in a '71 27 ft Yacht ,rear bath ? Kitchen sink was a breeze. Tom
There is Something Worse than Dying--- That is NOT LIVING !!!
PERFECT Trailer- Dog loves it- Wife hates it!!! You're not camping until you're miserable!
niftypkg is offline   Reply With Quote
Old 12-17-2005, 09:38 AM   #2
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
If it is original, it should not be O-rings in there, You may find you have rubber (possibly leather) washers. Remove the handle, then you can remove the valve.
This page shows a how to, although the faucet is not the came, but is the same principle
http://www.hammerzone.com/archives/p...er/replace.htm
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281
Member of VAC
www.balrgn.com
www.balrgn.com/Airstream.htm
balrgn is offline   Reply With Quote
Old 12-17-2005, 07:10 PM   #3
niftypkg's Avatar
Cornville , Arizona
Thanks bslgrn..........but my fauset is a single handle control. Push pull for water, twist for H&C. Tried from tub side..nothing. Other side may be problem. tom
Old 12-17-2005, 07:19 PM   #4
balrgn's Avatar
Images: 74
Bummer, have not disassembled one of those......... yet
Member of VAC
www.balrgn.com
Old 12-17-2005, 07:23 PM   #5
niftypkg's Avatar
Cornville , Arizona
I Thought that it was like the K. sink, which was easy. Oh well, lots of other things to play with! tom
Old 12-17-2005, 07:23 PM   #6
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 65
Airstream Registry
Sounds like yours is not original. Every bath faucet I have ever seen could be serviced with out tearing down a wall to get to it. If it has a knob on it, remove the center piece and go from there. If it has a handle, look for an allen screw on the bottom side.
Does this unit have a brand name on it? Maybe a picture?
Richard
Charter Member Four Corners Unit
Old 12-17-2005, 10:16 PM   #7
Profile:  1977 31' Sovereign
McHenry , Illinois
Single handle faucets
Look closely at just how your faucet is constructed. Then go down to the local hardware store and find one that looks like it and talk to the oldest guy there to find out how it comes apart.
Old 12-17-2005, 10:38 PM   #8
wkerfoot's Avatar
Profile:  1979 23' Safari
1954 29' Liner
Orange , California
Tom,
If it is a Moen fixture there is a special tool to remove the cartridge. The tool is available at the big box hardware stores, plumbing supply stores and I think local hardware stores.
Bill
Just my personal opinion
1973 Dodge W200 PowerWagon, 1977 Lincoln Continental
Old 12-19-2005, 11:18 AM   #9
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
I believe it's like my '66.
I think the manufacture is Delta????
All is accessible from the front! The single lever will come off by loosening the allen screw in the handle. Then there is a collar that comes off with a special tool. I used a screw driver in the slots. Be careful not to damage the slots. The insides will come out after the collar is removed.
I took the insides to HD and matched them up with the many different repair kits. Fixed both sinks and the shower.
Back to my repipe with pex.
>>>>>>>>>>>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.8L, E4OD, 3.55 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Old 12-19-2005, 04:48 PM   #10
niftypkg's Avatar
Cornville , Arizona
Thumbs up Bath tub and sink Faucets Faucets
Thanks Guys, I'll check it out this year. Thought there must be a better way.
Delta Faucet instead of the old Moen okay? 73ANDY Sinks, Showers & Toilets 7 05-01-2003 06:21 PM
tub p-trap 62 Overlander Sinks, Showers & Toilets 7 02-19-2003 11:24 AM
Sink Hand Pump Repair Gene Dallago Water Heaters, Filters & Pumps 4 10-23-2002 09:21 PM
Kitchen Faucet Repair niftypkg Sinks, Showers & Toilets 13 09-27-2002 05:02 PM
Leak in Water System Rich Palmieri Fresh Water Systems 6 06-27-2002 06:17 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
