Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 07-26-2005, 11:01 AM   #1
niftypkg
niftypkg's Avatar
Profile:  1971 27' Overlander
Cornville , Arizona
Thumbs up Tub & toilet
One:I need to replace badly corroded chrome bath tub drain. How do you get the old one out?
Two:Toilet sometimes fills with water. Trouble is that it can fill up the black water tank, which then.... ( don't ask) Lifting up on the pedals sometimes helps indicating that the flush valve is leaking. Solution: Turn water supply off at toilet or get busy replacing valve. Any suggestions?
Trailer is a 27' 1971 Overlander Int. w/rear bath.
There is Something Worse than Dying--- That is NOT LIVING !!!
PERFECT Trailer- Dog loves it- Wife hates it!!! You're not camping until you're miserable!
niftypkg is offline   Reply With Quote
Old 07-26-2005, 11:34 AM   #2
balrgn
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
Talking
On mine, I had to heat it up a bit first, if you do not have a heat gun a hair drier will work nicely. Get it warm to touch then turn it counter clockwise to loosen. I put 2 Screw drivers in and it came out fairly easy. IT WOULD NOT BUDGE with out heating it first. Got a replacement @ Home Depot......... Good luck!
There is a repair kit for the toilet if it is a Thetford.
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'77 20' Argosy MH (Peanut)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281
Member of VAC
www.balrgn.com
www.balrgn.com/Airstream.htm
balrgn is offline   Reply With Quote
Old 07-26-2005, 01:47 PM   #3
Buttercup
VAC Membership Chair
Buttercup's Avatar
Profile:  1977 27' Overlander
1954 25' Cruiser
VC Highlands , Nevada
Use the proper tool!
I used a wire stripper tool as my wrench. Stuck it down the hole and it spun right on out. I didn't have to heat mine up (but that doesn't mean you won't).
Here's what I did...
Don't let the IBT Scuttle the WBCCI - Just Vote NO! Save Wally! Buttercup Web site Looking for a unit? Check out the SaveWally Unit Guide.
WBCCI # 17330, VAC Membership Chair, CAC Member
2008 Mouse count:
Buttercup -
Airtini -
Buttercup is online now   Reply With Quote
Old 07-26-2005, 05:16 PM   #4
niftypkg
niftypkg's Avatar
Cornville , Arizona
Thanks for the timely advice. I will use the proper tools and also heat it first!
Old 07-28-2005, 10:06 AM   #5
niftypkg
niftypkg's Avatar
Cornville , Arizona
Tried to remove the drain yesterday. NO luck. Too hot to care in Az. Anyway, I assume that the drain screws out. It's threaded? Is there a nut on the other side?
No remarks now! Give it another try today. Tom
Old 07-28-2005, 11:20 AM   #6
balrgn
balrgn's Avatar
Images: 74
All of mine are threaded in. Might be quoting the obvious, but lefty tighty, righty loosey. (counter clockwise)
Member of VAC
www.balrgn.com
Old 07-28-2005, 12:48 PM   #7
BURNZEE
Profile:
I took a piece of 1" pipe and cut four notches in the end that matched the "cross" in the drain fittings bottom. I then could get a pipe wrench on it for much more leverage. I also heated it with a heat gun.
BURNZEE is offline   Reply With Quote
Old 07-28-2005, 02:32 PM   #8
niftypkg
niftypkg's Avatar
Cornville , Arizona
Thanks guys. I'll give it another try.
Old 07-28-2005, 04:15 PM   #9
Foiled Again
Foiled Again's Avatar
Virginia Beach , Virginia
Toilet Valve
Before you replace your flush valve, try just cleaning it. Icky job, but calcium buildup can cause small leaks because the seal can't work effectively.
When I got my new CCD, there was a strange little tool that looked like a plastic tongue depressor with velcro on one end. Luckily Vern told me what it was for before I decided it was a dental tool!
I read the instructions and now know how to use this little gizmo to clean the seal. If you don't have the gizmo, a self adhesive piece of velcro (the scratchy side) stuck on a tongue depressor would probably work just fine. More "right tools for the job" eh?
Say, have you considered leaving your slinky on and your black water valve open until you get this resolved?
good luck, Tin Lizzie
Foiled Again is online now   Reply With Quote
Old 07-28-2005, 05:17 PM   #10
niftypkg
niftypkg's Avatar
Cornville , Arizona
Good Idea, Tin Lizzie. The toilet does hold water so the valve should be tight but I will give it a try next time out. Thanks Tom
Old 07-28-2005, 10:52 PM   #11
niftypkg
niftypkg's Avatar
Cornville , Arizona
Talking Did it....bath drain
Not so easy. First, had to be 100 degrees in trailer. Tried the methods mentioned above .... nothing. Had to cut a segment out of the drain. I used a saber saw and cut two slits right through the threads. Then drilled holes on top and pried out the segment. Fun! Now to paint the tub, more fun. Tom
Old 07-29-2005, 01:37 PM   #12
balrgn
balrgn's Avatar
Images: 74
Bummer bout the heat, and the hard time it gave you, Nice job for keeping your cool and hanging in there to get it out! Good luck painting! Love the way ours came out, you'll be glad you did!
Member of VAC
www.balrgn.com
Toilet Replacement 3Ms75Argosy Sinks, Showers & Toilets 22 02-18-2007 08:51 PM
Rear toilet platform rotten, now what?? MontanaArgy Cabinets, Counter Tops & Furnishings 9 08-14-2005 07:46 AM
Toilet Overflow bentguy Sinks, Showers & Toilets 4 07-09-2004 04:07 PM
toilet doesn't hold water.... Chuck Sinks, Showers & Toilets 12 10-08-2002 11:03 AM
Toilet valve problem Charles Q Treichel Sinks, Showers & Toilets 1 09-04-2002 11:59 AM
