Old 03-31-2015, 02:01 PM   #1
1976 Argosy 30
Annapolis , Maryland
Trying to replace toilet
In 76 Argosy. Can't make connection between 17/32 copper and 1/2 pex. Any ideas?
kaa4111 is offline   Reply With Quote
Old 03-31-2015, 02:03 PM   #2
lahrfarm's Avatar
1985 31' Excella
Crescent , Oklahoma
Shark Bite connector
Get right or get left, and have a blessed day !
TAC OK-5
lahrfarm is offline   Reply With Quote
Old 03-31-2015, 06:25 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
And PEX makes 1/2" copper to PEX crimp connectors. You can solder it on and then PEX from there.
David
Old 03-31-2015, 07:31 PM   #4
1974 Argosy 20
Kooskia , Idaho
Your copper pipe most likely has been frozen and has expanded to a "new" size which nothing standard fits. You will need to go back to a fitting (which don't expand) and solder a new piece of copper in place, then go from there with other standard system pipes.
Trying to replace water heater. Help Okotoks Water Heaters, Filters & Pumps 6 06-25-2013 10:59 PM
To replace or not to replace the axles airstrmkids Axles 17 01-13-2011 06:20 AM
Trying to replace shore power cord tlavergne Electrical - Systems, Generators, Batteries & Solar 6 08-13-2010 08:51 PM
Trying to relocate the toilet in my 64GT DeweyGT General Repair Forum 1 02-01-2009 09:11 PM
Trying to replace Penguin A/C jcanavera Furnaces, Heaters, Fireplaces & Air Conditioning 23 01-20-2004 09:51 PM
