Old 09-28-2007, 07:20 PM   #1
1966 26' Overlander
Conover , Ohio
tough stool
I'm trying to remove the stool support from a 66 Overlander. I have removed all the screws I could find. The down pipe seems to be the hold up, and it all appears to be glued solid. I assume the next step is to actually cut the down pipe, or is it better to just destroy the top flange and replace it. Or am I missing something? The steel box under the tank is pretty rough as well. Is it pretty common for these to rot out? As you might guess, this all stems from a water leak that will require the back piece of flooring to be replaced. Any help is appreciated. Tom
air66stream is offline   Reply With Quote
Old 09-28-2007, 08:21 PM   #2
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
4 tough stools try Colace
ArtStream is offline   Reply With Quote
Old 09-28-2007, 09:58 PM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The RV closet flange is a common replacement part. If you need it gone, and it won't cooperate, hack it off, and go get a replacement, you can even get them at Home depot.
Also, try to ignore Micheal, he's been that way ever since we fed him the "funny" hot dog at a ralley a few years ago...
Old 09-28-2007, 10:09 PM   #4
Forrest's Avatar
1986 32' Excella
Aurora , Colorado
Images: 21
On both the '66 Airstreams I've had they were glued together.
Forrest
Out for coffee!
Forrest is offline   Reply With Quote
Tough As Tile Lumatic Upholstery, Blinds, Walls & Interior Finishes 5 12-07-2009 08:56 PM
Painting the tub and stool Judy Barde Sinks, Showers & Toilets 1 01-14-2007 06:09 PM
Ford Tough-vs-Elk arodriguez60 Tow Vehicles 17 01-09-2007 10:28 AM
Stool flange 1958 Globetrotter Sinks, Showers & Toilets 2 05-24-2005 04:27 PM
