Old 04-07-2010, 09:07 AM   #1
1975 27' Overlander
bay st louis , Mississippi
Tolet leak inside - help
My tolet on my 1976 land yaught is leaking inside the bathroom. Is there an easy way to diagnoise and fix this leak? Please help if you had similar leak, Sincerely, Wet Footed
Macymac is offline   Reply With Quote
Old 04-07-2010, 09:54 AM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Does the toilet leak all the time, indicating a fresh water leak in the input side, or does it leak when you flush it? Where is it leaking? If it leaks only when you flush it, and around the bottom, then the seal connecting the toilet to the flange for the waste tank is probably gone bad. Exactly how you get the toilet off to replace it depends on the toilet model you have. If you can post some pics of the toilet, someone here can probably help you with its removal.
Chris
Old 04-08-2010, 03:32 PM   #3
1975 27' Overlander
Photos attached
Found that the tolet has a water leak in the back side of it where the copper and white flexible tolet sprayer hook up in back. Not sure how to take tolet apart to fix leak. Please advise me on how to dis-assemble tolet
ID:	99804   Click image for larger version
Drip inside, how to find the leak outside? Bohemian Roof 5 12-03-2009 02:15 PM
Propane Leak Inside Trailer neil.ervin LP Gas, Piping, Tanks & Regulators 14 09-22-2009 08:22 AM
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 08:46 PM
What does the inside look like? till Interior Restoration Forum 4 02-18-2004 08:19 PM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
