Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 02-26-2003, 09:10 PM   #1
xtrm69
xtrm69's Avatar
Profile:
Exclamation toilets and accesories
Hello all:
I was wondering if you are able to use normal household toilets and accesories (toliet flange, beeswax) in the airstream bathroom?? Or do you have to buy specific toiletries??
xtrm69 is offline   Reply With Quote
Old 02-26-2003, 10:14 PM   #2
3Ms75Argosy
3Ms75Argosy's Avatar
Profile:  1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
toilets
I'm not sure about the older porcelain toilets in the earlier trailers, but on the approx 70's and up, no, a regular toilet wouldn't work, as the flange to wall clearance wouldn't allow a regular toilet to fit. You also would need to figure out some kind of flapper valve to keep the water in the p-trap while you drove, not to mention not enough vertical room for the water tank.
The new toilets (and old star-magic thetfolds) come with a rubber flange that seals between the holding tank and the toilet. It all comes with the new toilet. Search for "toilet replacement" or "Bravura" to see my photos of toilet replacement in a 75 Argosy.
Marc
