Old 05-17-2018, 10:30 AM   #1
Cispook's Avatar
2017 27' Flying Cloud
Chillicothe , Ohio
Toilet Water Flow
Water flow on refill is just a trickle. Nothing visibly wrong. Hold pedal slightly depressed and fill rate increases to a strong trickle. Unexpected change following a week of camping prior to this trip.
Does the winged connector from water line to toilet have a screen in place? Thinking mineral deposits.
Cispook is offline   Reply With Quote
Old 05-17-2018, 12:58 PM   #2
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Yes. Mine had that problem this winter. Crud in the screen. Clean that out and the waters will flow.
Next thing to do is always use a camco water filter at the shore pedestal. Will reduce the amount of crud at all your fixtures.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 05-17-2018, 01:24 PM   #3
Cispook's Avatar
Chillicothe , Ohio
I have the blue filter in place. Iíve noticed that even with that in place I still get mineral deposits in the screens. Iíll pull that wing nut off and scrub the screen.
Old 05-17-2018, 02:05 PM   #4
Cispook's Avatar
Chillicothe , Ohio
Pat
Was the screen behind this wing but?Click image for larger version
Old 05-17-2018, 02:19 PM   #5
Cispook's Avatar
Chillicothe , Ohio
Pulled same. No screen. Good flow at water line. Toilet must have failed.
Old 05-19-2018, 09:40 AM   #6
Ready-to-Travel
pmclemore's Avatar
Hmm. I'll go look at mine shortly. Did you receive documentation on the toilet along with the rest of your package?
Pat
AIR 3987
TAC VA-2
WBCCI 4596
Old 05-19-2018, 09:22 PM   #7
1986 31' Sovereign
Miami , Florida
On mine, the foot pedal acts as a cam that opens the water valve mounted on the side of the toilet. The valve is "t" shaped with the actuating plunger riding on the cam. That valve has screen on the input side.
After I replaced my fresh water tank two years ago, that screen became plugged with plastic shavings causing the same symptoms you have. Pulled the valve, cleaned it out and problem solved.
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 05-20-2018, 11:25 AM   #8
Cispook's Avatar
Chillicothe , Ohio
Toilet Water Flow
Called manufacturer and then read reply from n2916s ... yep the screen is in the valve as described. Approx 1Ē inside. Used a mirror and flashlight to identify that I was clogged with deposits. Used q-tips to clean up the mess and we are back to a working toilet.
From the manufacturing folks I learned that even if the toilet failed there is no need to remove to repair. The foot pedal housing contains a replaceable cartridge - bar the actual porcelain being broke.
Going to send an email to AS Jackson Center as the Help Desk there told me there was no screen and a failed toilet has to be replaced.
Thanks everyone.
Old 05-20-2018, 01:32 PM   #9
Cispook's Avatar
Chillicothe , Ohio
Pat
Documents showed a screen; location wasnít clear. Hence my call to Dometric and AS.
Old 05-20-2018, 01:54 PM   #10
Ready-to-Travel
pmclemore's Avatar
Sorry, slow to get back. When mine clogged, like yours, I feared the worst as well. Luckily I had a manual for it with my other trailer documents and remember it talked about the cartridge. I forgot the details until I read your account.
Pat
AIR 3987
TAC VA-2
WBCCI 4596
Low water flow in Thetford toilet kds Sinks, Showers & Toilets 1 09-19-2015 09:52 PM
'70 overlander 27' steady flow toilet bowl capt ken Plumbing - Systems & Fixtures 2 11-04-2013 12:37 PM
Toilet flow woe BillTex Sinks, Showers & Toilets 3 10-08-2007 06:51 PM
toilet of the endless flow terratravelr Sinks, Showers & Toilets 8 10-08-2007 09:49 AM
Shower Dribbles ... Faucet and Toilet flow great Killo1 Fresh Water Systems 3 03-18-2007 09:54 PM
