Old 06-09-2012, 09:43 PM   #1
VeggieBullet's Avatar
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel , Florida
Toilet Valve - Replacement
Working on the bathroom plumbing I realized that we have a water leak from the back of the toilet.
Decided to document project the replacement of the valve and post it hoping that it can help other members.
Any inputs or corrections please let us know.
Regards
Still One Nation under GOD
2 chronicles 7:14
VeggieBullet is offline   Reply With Quote
Old 06-09-2012, 09:48 PM   #2
1973 31' Sovereign
2007 20' Safari SE
toilet is out!
Out and up side down for easy access to work.
The Valve has a small crack visible to the eye but not sure if it will be visible to the camera.
So far it looks simple, 2 screws and 1 nut.
ID:	160573   Click image for larger version
2 chronicles 7:14
Old 06-09-2012, 10:07 PM   #3
Those replacement parts are available.
Old 06-10-2012, 06:05 AM   #4
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Same valve that cracked on ours. It's just my personal opinion but I'd replace the copper feed line with flexible stainless. We used a dishwasher feed line from Lowes or HD and the appropriate fittings to install it. I think the rigid copper connection speeds the failure of the plastic valve. If nothing else, it will be much easier to remove or reinstall.
Old 06-10-2012, 06:22 AM   #5
Herm and Debby's Avatar
1970 25' Tradewind
Cincinnati , Ohio
Same valve, same crack! We did the same as Ganglin & used the flexible braided lines. Did the replacement last year and no problems yet!
Herm and Debby is offline   Reply With Quote
Old 06-10-2012, 07:13 AM   #6
1973 31' Sovereign
2007 20' Safari SE
We have Pex now and we were thinking on the flexible lines with a and a valve so it gets easier for future repairs. But how is the pex regarding the flexibility? It seems fine.
We were thinking on keeping pex and a sharkbite elbow.
BTW
how much does the part goes for? and any part #?
2 chronicles 7:14
Old 06-10-2012, 07:33 AM   #7
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
It probably froze. Well that's what happened to mine when it had the crack in it.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 06-10-2012, 07:41 AM   #8
1981 31' Excella II
New Market , Alabama
That is a low point in the system and it will freeze and break unless you blow it out with air. If you forgot to purge that valve of water and it is easy to do it will freeze.
Perry
Old 06-10-2012, 08:23 PM   #9
1973 31' Sovereign
2007 20' Safari SE
update
Well it wasn't that hard or complicated at all to remove. 2 screws and the nut metric #11 and it was out.
Not sure the reason for the crack but it will need to be replaced. Is a very small crack but it leaks not sure if it can be seen.
Does anyone has the part #?
ID:	160638   Click image for larger version
ID:	160640   Click image for larger version
2 chronicles 7:14
Old 06-10-2012, 08:34 PM   #10
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
It should be 09868.
Here's one on doing a quick Google search that showed up on Ebay. Check Inland RV and Out of Doors Mart - they may have it also.
RV, Thetford Aqua-Magic Toilet Valve Replacement Package | eBay
Another source:
http://www.amazon.com/Thetford-09868.../dp/B0006H9346
Old 06-11-2012, 08:39 PM   #11
1973 31' Sovereign
2007 20' Safari SE
similar part
found this in a store today, thinking on adding an elbow with a barb and an another elbow with sharkbite for the supply line.
ID:	160755   Click image for larger version
2 chronicles 7:14
Old 06-11-2012, 09:27 PM   #12
rogerdodger's Avatar
Fresno/Clovis , California
Ok, so, how do you get the toilet out?
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 06-11-2012, 09:53 PM   #13
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Not sure I'd replace it with a different part - but that's just me. good luck...
Old 06-12-2012, 05:48 AM   #14
1973 31' Sovereign
2007 20' Safari SE
oops
I guess we decided to document it all once the toilet was out.
Not that hard at all, 2 bolts secure the toilet to the flange .
I was under the impression that it will be a small surgery
Was thinking on document the placing the toilet process and post the pics backwards as a " toilet removal"
2 chronicles 7:14
