Old 07-13-2012, 12:45 PM   #29
VeggieBullet's Avatar
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel , Florida
Originally Posted by perryg114 View Post
Remember hand tight with teflon tape.
Perry
yeah....and now you are telling me...
BTW Aage
Macro function...I'm taking pics with my old BlackBerry...not sure if there is such an option...if there is please let me know.
Still One Nation under GOD
2 chronicles 7:14
VeggieBullet is offline   Reply With Quote
Old 07-13-2012, 01:22 PM   #30
Ottawa , ON
Doesn't look like they do. But if you have time and a disposable camera, a screwdriver and some scotch tape, you can make one.
how-to: do cheap macro photography on a BlackBerry | makebright
Old 07-13-2012, 02:11 PM   #31
1973 31' Sovereign
2007 20' Safari SE
oooops!
Can't find the bolts to secure the toilet to the flange.
It's been a while since I got the toilet out and got the floors done so no idea where I place them.
They didn't come with the valve, the seal did but no the bolts.
1. Does anyone remembers the size by any chance?
2. Also is it recommended to used any sealers while placing the seal between the toilet and the flange?
ID:	163050   Click image for larger version
2 chronicles 7:14
Old 07-13-2012, 02:16 PM   #32
rogerdodger's Avatar
Fresno/Clovis , California
Hmmmmm. Broke the new one! Sounds like one of my projects. Still waiting for backwards install, or is it reinstall? I'm so confused. LOL
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 07-13-2012, 07:38 PM   #33
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
oooops! Can't find the bolts to secure the toilet to the flange.
should be standard 1/4" closet bolts
nope, just the seal by itself
best,
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 07-13-2012, 08:30 PM   #34
1973 31' Sovereign
2007 20' Safari SE
thanks Jim
Any idea about the length?
2 chronicles 7:14
Old 07-13-2012, 08:33 PM   #35
1973 31' Sovereign
2007 20' Safari SE
WOW....and that little cover is the one making it all....?
mine BB is not that new...will still work...?
We were under the impression that this was an Airstream forum, but we obviously understimated the full capacity of the resources here
2 chronicles 7:14
Old 07-13-2012, 09:01 PM   #36
Ottawa , ON
Exclamation Say... Check this please?
Y'know, I could be wrong (after all, it happens regularly ) but I -think- you may have the closet gasket (you call it the "seal") on backwards.
Would somebody have a look and see if I am right? Been a long while since I did one of those, but I think that wide part goes up against the underside of the toilet...
If I am right, just pull the gasket off, turn it around, and shove it back on.
I'm referring to the top picture in post #31
Old 07-13-2012, 09:55 PM   #37
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
thanks Jim
iirc, standard length is ~ 2.25", long is ~ 3.5". my guess would be the shorter ones. two sets should cost < $5; return the unused ones. you simply hacksaw any extra length off after installation.
you might be right Aage, especially if it were a wax ring and not a rubber (?) gasket. I'd look up the install instructions from the manufacturer to be sure.
best,
Joseph & Gabrielle
Old 07-14-2012, 06:14 AM   #38
1973 31' Sovereign
2007 20' Safari SE
thanks for the observation, I just had it laying there and that was also a curiosity that I had.
While removing the toilet I figured that whatever it was there as a closet gasket it wasn't rubber, I thinking that it had a Wax Ring.
Based on researchs people tend to dislike the Wax Ring for many reasons and I'm assumming that the original rubber closet gasket should be better and hope that someone jumps in regarding the correct direction of it before the installation.
thanks for the help regarding the length...I really don't like buyin 8 different sizes and combinations of screws and bolts to ending using just 2....and then ending loosing the other 6
2 chronicles 7:14
Old 07-14-2012, 06:02 PM   #39
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
They go with the 2 you can't find, although a week after you finish, "there they are".
Gene
Old 07-14-2012, 06:35 PM   #40
1973 31' Sovereign
2007 20' Safari SE
Gene
I know....always like that!
Any ways the toilet is set and working...will place some pics in a few..
2 chronicles 7:14
Old 07-14-2012, 06:39 PM   #41
1973 31' Sovereign
2007 20' Safari SE
more supply
went to the store and got some more parts....
ID:	163138   Click image for larger version
2 chronicles 7:14
Old 07-14-2012, 06:41 PM   #42
1973 31' Sovereign
2007 20' Safari SE
Ready to go...
ID:	163141   Click image for larger version
2 chronicles 7:14
