06-22-2012, 09:02 PM
#21
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
let's see how it fits..
mmm....so far so good
Still One Nation under GOD
2 chronicles 7:14
06-22-2012, 09:05 PM
#22
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
and the sharkbite..
and ready for test...
2 chronicles 7:14
06-23-2012, 05:24 AM
#23
1981 31' Excella II
New Market
, Alabama
You must have an improved part. The one I replaced looked just like your old one. The old valve was a POS cheap design.
Perry
07-11-2012, 04:37 PM
#24
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
Perry
Hi Perry
That part is actually for a different toilet model and since this place had this only part on their stock and for 10$ cheaper...(it looks like it's been sitting there for a WHILE) we decided to get it and figure it out later about how to adapt.
I didn't set up the toilet yet since we decided to replace the floors and that was documented as well and will be the subject for another thread.
But hope to be done soon, after floors, plumbing, after that polishing and clearance marker lights and ready to roll, so a lot on the plate!!
Camera is totaled so will be hard to document everything but looking on ebay for a decent one at a good price.
2 chronicles 7:14
07-13-2012, 08:59 AM
#25
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
ups...to much torque
Ups....to much torque and I broke the new valve !!!!
Tried JB weld before getting another part....NO LUCK
2 chronicles 7:14
07-13-2012, 09:05 AM
#26
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
back to work...
JB Weld didn't help with the hope of keeping the "new" but cracked valve..
Got a new valve today and ready to get this done..
Will keep this active and trying to document the placing and replacing pics posted...we own that to RogerDodger
2 chronicles 7:14
07-13-2012, 11:23 AM
#27
1981 31' Excella II
New Market
, Alabama
Remember hand tight with teflon tape.
Perry
07-13-2012, 11:26 AM
#28
Ottawa
, ON
Use your camera's MACRO function for closeups. Hard to see anything if you don't.
“Courage is being scared to death, but saddling up anyway.” ...John Wayne...........................
07-13-2012, 12:45 PM
#29
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
Perry
yeah....and now you are telling me...
BTW Aage
Macro function ...I'm taking pics with my old BlackBerry...not sure if there is such an option...if there is please let me know.
2 chronicles 7:14
07-13-2012, 01:22 PM
#30
Ottawa
, ON
Doesn't look like they do. But if you have time and a disposable camera, a screwdriver and some scotch tape, you can make one.
how-to: do cheap macro photography on a BlackBerry | makebright
07-13-2012, 02:11 PM
#31
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
oooops!
Can't find the bolts to secure the toilet to the flange.
It's been a while since I got the toilet out and got the floors done so no idea where I place them.
They didn't come with the valve, the seal did but no the bolts.
1. Does anyone remembers the size by any chance?
2. Also is it recommended to used any sealers while placing the seal between the toilet and the flange?
2 chronicles 7:14
07-13-2012, 02:16 PM
#32
1974 Argosy 28
Fresno/Clovis
Hmmmmm. Broke the new one! Sounds like one of my projects. Still waiting for backwards install, or is it reinstall? I'm so confused. LOL
Roger
07-13-2012, 07:38 PM
#33
2002 25' Safari
1977 20' Argosy 20
northern valley
, new jersey
oooops! Can't find the bolts to secure the toilet to the flange.
should be standard 1/4" closet bolts
nope, just the seal by itself
best,
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
https://defendwally.org/
07-13-2012, 08:30 PM
#34
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
thanks Jim
Any idea about the length?
2 chronicles 7:14
07-13-2012, 08:33 PM
#35
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
Originally Posted by Aage
WOW....and that little cover is the one making it all....?
mine BB is not that new...will still work...?
We were under the impression that this was an Airstream forum, but we obviously understimated the full capacity of the resources here
2 chronicles 7:14
07-13-2012, 09:01 PM
#36
Ottawa
, ON
Say... Check this please?
Y'know, I could be wrong (after all, it happens regularly ) but I -think- you may have the closet gasket (you call it the "seal") on backwards.
Would somebody have a look and see if I am right? Been a long while since I did one of those, but I think that wide part goes up against the underside of the toilet...
If I am right, just pull the gasket off, turn it around, and shove it back on.
I'm referring to the top picture in post #31
07-13-2012, 09:55 PM
#37
2002 25' Safari
1977 20' Argosy 20
northern valley
, new jersey
thanks Jim
iirc, standard length is ~ 2.25", long is ~ 3.5". my guess would be the shorter ones. two sets should cost < $5; return the unused ones. you simply hacksaw any extra length off after installation.
you might be right Aage, especially if it were a wax ring and not a rubber (?) gasket. I'd look up the install instructions from the manufacturer to be sure.
best,
Joseph & Gabrielle
07-14-2012, 06:14 AM
#38
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
thanks for the observation, I just had it laying there and that was also a curiosity that I had.
While removing the toilet I figured that whatever it was there as a closet gasket it wasn't rubber, I thinking that it had a Wax Ring.
Based on researchs people tend to dislike the Wax Ring for many reasons and I'm assumming that the original rubber closet gasket should be better and hope that someone jumps in regarding the correct direction of it before the installation.
thanks for the help regarding the length...I really don't like buyin 8 different sizes and combinations of screws and bolts to ending using just 2....and then ending loosing the other 6
2 chronicles 7:14
07-14-2012, 06:02 PM
#39
Master of Universe
2008 25' Safari FB SE
Grand Junction
They go with the 2 you can't find, although a week after you finish, "there they are".
Gene
07-14-2012, 06:35 PM
#40
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
Gene
I know....always like that!
Any ways the toilet is set and working...will place some pics in a few..
2 chronicles 7:14
