Old 06-20-2004, 10:48 AM   #1
Red face Toilet Valve Replacement
I am needing a replacement toilet valve for my 1967 24' Tradewind. I'm not sure if the toilet is original, however the tag says Mansfield Sanitary, Inc; Model 910; Serial # 206134. The valve is attached to the side of the toilet & allows water into the bowl when the foot pedal is depressed. Any help would be appreciated. I submitted a photo of the valve in the member section & will try to attach it here as well.
Thanks, Don
[img]C:%5CDocuments%20and%20Settings%5CDon%5CMy%20Docum ents%5CAirstream%5CPhotos%5Cvalve.jpg[/img]
girardblvd is offline   Reply With Quote
Old 06-20-2004, 05:13 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Welcome to the forum!
I wish I could answer your first post with positive information, but I cannot. I seriously doubt you will find the parts you need, and will have to replace your toilet. I had a Thetford toilet in my '67 which needed the same part you do, and Thetford does not sell it anymore.
I decided these companies make more money selling new toilets than maintaining an inventory for a 37 year old toilet.
But, that's probably why they are still in business.
Good luck in your search,
Tom
Old 06-24-2004, 09:59 AM   #3
Thanks for the information & the welcome - do you have any information on replacement toilet sources? I'm wanting to do as much of the work as I can.
Don
Tom
Toilet Sprayer Valve Leak 66Overlander Sinks, Showers & Toilets 6 06-21-2004 02:03 AM
Holding tank valve replacement Van Waste Systems, Tanks & Totes 4 05-04-2004 01:06 AM
Dunp Valve replacement David Hall Waste Systems, Tanks & Totes 0 02-17-2004 10:35 PM
Toilet replacement Globestream Sinks, Showers & Toilets 2 09-23-2003 12:52 PM
Toilet valve problem Charles Q Treichel Sinks, Showers & Toilets 1 09-04-2002 11:59 AM
