Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 09-04-2002, 11:34 AM   #1
Charles Q Treichel
Profile:
Toilet valve problem
I am fixing up and old 77. The problem I am having with the toilet is than the water will not shut off when the bowl automatically fills and therefore overflows. There does not appear to be any access to the valve that controls this. For this reason I have to temporarily turn off the water to the toilet after each use. Any tips on how this system works and how to fix it would be greatly appreciated.
Charles Q Treichel is offline   Reply With Quote
Old 09-04-2002, 11:59 AM   #2
mkeith54
mkeith54's Avatar
Profile:  1976 26' Argosy 26
New Florence , Missouri
If you go to the Thetford site: http://www.thetford.com/parts.cfm and select the model you have you ca n see a parts break down. When ours had problems I added up the bits an pieces and figured in the long run it was cheaper to replace theold one with a new one for $156.00 plus tax. YMMV
Mike
Mike Keith
75 Argosy 26'
96 Ford F-250 PowerStroke
WBCCI 4503
Gr8r STL Unit
mkeith54 is offline   Reply With Quote
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 03:37 PM
Black & Grey valve trouble camphost Waste Systems, Tanks & Totes 51 08-18-2006 09:45 AM
Toilet changing tips... drboyd Sinks, Showers & Toilets 2 07-18-2006 02:28 PM
Followup to valve stem failure dtbw Wheels 0 10-29-2003 09:40 AM
64 Swirlomatic toilet MW64OVERLANDER Sinks, Showers & Toilets 1 10-27-2003 10:57 PM
