Old 11-30-2006, 04:40 PM   #1
grannyred's Avatar
1959 22' Flying Cloud
Bowden , West Virginia
Toilet trap door/slide adjustment
Is there an adjustment that can be made to limit how far the trap door/slide can open? Toilet worked great until the last two trips. Now when I press the foot pedal, the trap door/slide opens all the way and sticks open. The door/slide appears to be hanging up on the rubber gasket/seal that the door/slide rest on.
I have put the rubber gloves on and made sure there is nothing impeding the door/slide from returning to its closed position. I have put some oil in the toilet to lubricate the door/slide. Nothing has helped. The only thing that was helped has been building a small platform under the foot pedal. The platform restricts the how far the foot pedal can travel and restricts how far the door/slide can open. This is a temporary fix.
As I said, this is a recent problem. There is a wire on the foot pedal that connects to the door/slide somewhere inside the toilet. Is there an adjustment that can be made to this cable?
grannyred is offline   Reply With Quote
Toilet Replacement 3Ms75Argosy Sinks, Showers & Toilets 22 02-18-2007 07:51 PM
Rear toilet platform rotten, now what?? MontanaArgy Cabinets, Counter Tops & Furnishings 9 08-14-2005 06:46 AM
Toilet Overflow bentguy Sinks, Showers & Toilets 4 07-09-2004 03:07 PM
toilet doesn't hold water.... Chuck Sinks, Showers & Toilets 12 10-08-2002 10:03 AM
Toilet valve problem Charles Q Treichel Sinks, Showers & Toilets 1 09-04-2002 10:59 AM
