Old 02-09-2016, 07:37 PM   #1
2016 27' Flying Cloud
Dade City , Florida
Unhappy Toilet to Close to Cabinet
We just purchased a 2016 27FB. Realized on the first trip out that the toilet is so close to the rounded sink cabinet that I have turn to sit on the pot.
Does anyone know if the toilet can be turned a few degrees toward the door to add a little clearance?
Thanks in advance.
Ernster is offline   Reply With Quote
Old 02-09-2016, 07:43 PM   #2
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Thanks in advance.
Yes, the toilet can be turned. You will have to remove the toilet and turn the flange to where you want it. Not hard to do.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
bwoodtx is offline   Reply With Quote
Old 02-09-2016, 08:19 PM   #3
jayseejay's Avatar
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach , Florida
Hi there. Here is a picture of the flange from a our prior coach (2011 Flying Cloud), which is probably similar to your flange. Like you, I wanted to rotate the toilet (in our case, we wanted to straighten it as it pointed too far toward the door). I removed the 8 pictured Phillips head screws, and was then unable to make the flange rotate at all, even with substantial rotational force, and gave up. I hope you have better luck (and more ingenuity) then I did.
Best,
Joe
Name:	ImageUploadedByAirstream Forums1455073997.579261.jpg
jayseejay is offline   Reply With Quote
Old 02-09-2016, 08:48 PM   #4
Dade City , Florida
Is the flange welded or glued in place to the tank?
Old 02-09-2016, 08:57 PM   #5
1977 23' Safari
Carberry , Manitoba
In older Airstreams (mine is a 77) it is threaded in. sometimes hard to get started but in mine there are two slots in the flange that will accept crossed large screwdrivers to rotate it. I imagine there is a special tool plumbers have that fits the two slots/notches
ymmv - Lorryb
cp1977 is offline   Reply With Quote
Old 02-09-2016, 10:51 PM   #6
1998 30' Excella 1000
Livingston , Texas
I rotated my flange to adjust my toilet too. It was threaded on my '98. From advice on this forum I made a tool with about 2' of 2x4 and two bolts screwed into it spaced to fit the flange slots.
Siegmann is offline   Reply With Quote
Under-Cabinet Light = Scorched Cabinet! MohawkDaddy General Interior Topics 7 09-24-2015 02:47 PM
Toilet seal for vintage toilet thinktankair Waste Systems, Tanks & Totes 0 06-09-2014 12:37 AM
Changing a toilet to a standard toilet bamamama Waste Systems, Tanks & Totes 8 07-21-2012 06:12 PM
Replacing old platform toilet with "regular" toilet? Mrs.S Plumbing - Systems & Fixtures 4 11-21-2011 03:52 PM
"gate" to black tank from toilet won't close jeff&jess Waste Systems, Tanks & Totes 9 06-14-2006 09:25 PM
