Old 06-16-2017, 01:37 PM   #1
Traveler
TravlinMan's Avatar
2017 25' International
Staunton , Virginia
Toilet squeakin
After several months of ownership, my toilet is now squeaking when I lean forward to stand up. And it seems to have more flexibility on it than it did when I got it. It moves more when I clean it than it used to. But I took off the two bolt caps in either side at the bottom and both seem tight. Do these toilets loosen over time?
Thank you.
TravlinMan is offline   Reply With Quote
Old 06-16-2017, 01:44 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
The gasket compresses over time. I would give the flange bolts a turn....if simply you don't want the toilet to give away you position, spray a little silicone around the bottom.
CRH is offline   Reply With Quote
Toilet seal for vintage toilet thinktankair Waste Systems, Tanks & Totes 0 06-09-2014 12:37 AM
Changing a toilet to a standard toilet bamamama Waste Systems, Tanks & Totes 8 07-21-2012 06:12 PM
Replacing old platform toilet with "regular" toilet? Mrs.S Plumbing - Systems & Fixtures 4 11-21-2011 03:52 PM
Thetford Toilet Repair??? Galaxy Low Profile ViewRVs Sinks, Showers & Toilets 11 05-03-2010 03:27 PM
Raise the toilet FrankR Sinks, Showers & Toilets 0 03-15-2002 09:57 PM
