After several months of ownership, my toilet is now squeaking when I lean forward to stand up. And it seems to have more flexibility on it than it did when I got it. It moves more when I clean it than it used to. But I took off the two bolt caps in either side at the bottom and both seem tight. Do these toilets loosen over time?
The gasket compresses over time. I would give the flange bolts a turn....if simply you don't want the toilet to give away you position, spray a little silicone around the bottom.
