Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 07-27-2016, 08:40 PM   #1
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Tavares , Florida
Toilet Seal Replacement?
I am in the process of replacing the floor (with Armstrong vinyl tile) in my 2009 25FB Int. When I get to the bathroom and lift the toilet to replace the linoleum under it, will I need to replace the toilet seal? Or can the existing seal be reused?
I have looked at some YouTube videos and it looks like it has a foam cushion seal of some sort. There is no evidence that it is leaking.
Thanks!
Old 07-27-2016, 09:37 PM   #2
2007 22' International CCD
New seal is always a better idea. You won't be able to get it back together exactly as it was. Cheap precaution against leaks both water and sewer gas.
Old 07-28-2016, 12:01 AM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
Replace it. They are less than 10 bucks. I pulled my toilet twice in the past year to deal with a leaky flush valve. I put a new seal in both times to be on the safe side.
CRH is offline   Reply With Quote
Old 07-28-2016, 07:59 PM   #4
Hans627's Avatar
Tavares , Florida
Thanks for the recommendation. Replacing the seal does make sense. Are they readily available?
Old 07-28-2016, 08:02 PM   #5
CRH
1995 25' Excella
xxxxx , xxxxxx
Any RV dealer has them. I got mine from eBay.
Old 07-28-2016, 08:17 PM   #6
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
http://odmrv.com/catalog/index.php?m...oducts_id=1174
Alan
Toilet seal for vintage toilet thinktankair Waste Systems, Tanks & Totes 0 06-09-2014 12:37 AM
Installing exterior lights-to seal or not to seal Belegedhel Lights - Interior & Exterior 7 10-26-2013 07:14 AM
To 'seal' or not to 'seal'?? b8sfamily Floor Finishes 6 03-31-2009 06:13 AM
Vertical lip seal and trim seal for Classic Motorhomes rdm General Motorhome Topics 16 05-22-2006 07:49 PM
