Old 02-07-2007, 07:54 PM   #1
cookeville34's Avatar
Auburntown , Tennessee
Send a message via Yahoo to cookeville34
toilet seal
Does the toilet in my 1979 AS need a wax seal or sealant around the base? I pulled the toilet to replace the carpet in the rear bathroom and noticed the toilet had been leaking. It appeared it had some kind of white sealant around the flange, but its dried up and hard as a rock. Thank you.
1979 Airstream Sovereign International, 31'. VIN# I31T9J0162
1992 Buick Roadmaster Wagon, 5.7L - V8, stock 5000# tow rating, posi, aux trans cooler, rear coil over shocks, 2" rear spring lift kit, flowmaster exhaust.
cookeville34 is offline   Reply With Quote
Old 02-07-2007, 08:00 PM   #2
Retired.
. , At Large
Every one I have removed has had a soft foam (at least it was soft when installed) ring, and should be replaced before re-installing the toilet.
Toilet Replacement 3Ms75Argosy Sinks, Showers & Toilets 22 02-18-2007 07:51 PM
Toilet Overflow bentguy Sinks, Showers & Toilets 4 07-09-2004 03:07 PM
toilet doesn't hold water.... Chuck Sinks, Showers & Toilets 12 10-08-2002 10:03 AM
Door Seal Types ??? Road Ruler Doors & Locks 3 09-07-2002 05:53 PM
1960 toilet 60stradewind Sinks, Showers & Toilets 2 08-26-2002 10:34 PM
