Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 08-14-2016, 01:11 PM   #1
1985 25' Sovereign
Midvale , Utah
Toilet replacement in an '85 Sovereign
We would like to upgrade the toilet in our 1985 Sovereign 25SB. The existing toilet is installed on a box. Does anyone know if we can remover this box, and re-plumb to mount the toilet directly to the floor? Thanks.
1985 Sovereign 25SB
Airstream Punk BLOG
Stream_Punk is offline   Reply With Quote
Old 08-14-2016, 01:32 PM   #2
1976 Argosy 26
Fair Oaks , California
If your toilet is mounted on a "box" then the box contains the holding tank mounted above the floor. If you wanted to floor mount the toilet , then a holding tank would need to be mounted in the frame area . Not sure if there is room under there .
Argosy Heir is offline   Reply With Quote
Old 08-14-2016, 02:28 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you cant lower the box lower the toilet. Toilets are made extra high and extra LOW.
http://www.pplmotorhomes.com/parts/c...6W6hoCoZ7w_wcB
2004 Excursion 4x4
Old 08-20-2016, 08:01 AM   #4
1985 25' Sovereign
Midvale , Utah
I finally did some poking around the '85 Sovereign. This is what I found under the toilet.
The toilet is only 12" tall off the top of the 'box'. A short search on the internet finds 'low-profile' toilets ranging from 13-15" tall. I already feel this toilet is too tall and wife is 10" shorter than I. I may look into modifying the black tank by removing the wedge and replacing it with a patch and a floor mounted flange to place a 'china bowl' type unit in it's place.
Any thoughts?
1985 Sovereign 25SB
Airstream Punk BLOG
Old 08-20-2016, 11:42 AM   #5
1979 23' Safari
Wayland , New York
Any thoughts?
Cutting off the "wedge" and patching it is not likely to go well. It's difficult to get any type of adhesive to bond with the plastic that the tank is made of. Chances are you'd end up ruining the tank and needing a replacement.
Best bet would be a low profile toilet with a small step in front of it to aid with the height issue.
Second best bet would be to replace the tank with one that will fit under the floor flush with the fittings in necessary positions.
Third best bet, cut as you described use a lot of sealant between the patch and tank and stainless screws to hold the patch down. It should never be under pressure and is on top of the tank do the leak potential is low, but you want to be sure it's water/gas tight. A piece of plywood over the top spanning to the floor to keep the toilet weight off of the tank fitting itself.
My thoughts.
Old 08-20-2016, 02:03 PM   #6
1985 25' Sovereign
Midvale , Utah
All good points. Thanks.
1985 Sovereign 25SB
Airstream Punk BLOG
sovereign
Toilet seal for vintage toilet thinktankair Waste Systems, Tanks & Totes 0 06-09-2014 12:37 AM
Changing a toilet to a standard toilet bamamama Waste Systems, Tanks & Totes 8 07-21-2012 06:12 PM
Replacing old platform toilet with "regular" toilet? Mrs.S Plumbing - Systems & Fixtures 4 11-21-2011 03:52 PM
Toilet Replacement 3Ms75Argosy Sinks, Showers & Toilets 22 02-18-2007 07:51 PM
Toilet Replacement for 66 Landyacht SterlingM Sinks, Showers & Toilets 0 02-03-2003 12:35 PM
