Old 07-20-2014, 03:40 PM   #1
1988 25' Excella
Trumbull , Connecticut
Toilet replacement '88 Excella
Trying to replace toilet in my TT. Finally got old one removed and tried to rotate the toilet flange so the new one would be straight, but it would not budge. I could see the drain pipe start to flex so didn't continue as I was afraid of breaking something. Has anyone ever used a flange repair ring on top of the original ring . The repair rings are are made of stainless steel and are about 3/8" thick so that would raise the whole assembly up that much and I don't know if there is anough room on the underside of new toilet. Any comments or suggestions.
Thanks nm1oqrz
nm1oqrz is offline   Reply With Quote
Toilet seal for vintage toilet thinktankair Waste Systems, Tanks & Totes 0 06-09-2014 12:37 AM
Excella vs Excella II vs Excella 500 vs Excella 1000 ElCamino Man Trailer Values 5 03-21-2013 02:32 PM
Changing a toilet to a standard toilet bamamama Waste Systems, Tanks & Totes 8 07-21-2012 06:12 PM
Replacing old platform toilet with "regular" toilet? Mrs.S Plumbing - Systems & Fixtures 4 11-21-2011 03:52 PM
Toilet Replacement 3Ms75Argosy Sinks, Showers & Toilets 22 02-18-2007 07:51 PM
