Old 07-23-2006, 07:53 AM   #1
Dano57's Avatar
1979 31' Excella 500
Edmond , Oklahoma
Question Toilet Replacement???
We are in the process of repairing plumbing in a 79 Excella 500 and have discovered a leak in the toilet plumbing. I have never been a fan of the Thetford low model toilets and was thinking of replacing it with a taller unit. What are the opinions here as to a good replacement? Might as well get everything right now so I don't have to worry about it later.
Dan
Dano57 is offline   Reply With Quote
Old 07-23-2006, 08:48 AM   #2
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
OlyPen , Washington
Images: 90
Try looking at the sealand traveler and traveler lite models. Thet are made of porcelin and cone in two heights - also two colors - white and bone.
Many of us have installed this little gem with great sucess and it seems to be durable and reliable. It comes with a cheesy plastic seat - but as it is a standard houshold size - replacement with the seat of your choice is simple. You view them online as well as the specs at PPL Motors
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 07-23-2006, 03:25 PM   #3
1960 24' Tradewind
santa barbara , California
Hello ,
The sealand traveler lite is a great replacement ,highly recommend it .
Scott
scottanlily is offline   Reply With Quote
Old 07-23-2006, 06:46 PM   #4
Dano57's Avatar
Edmond , Oklahoma
I like the look of the traveler, are the flanges all standard or do I have to change anything? I assume it is like a household toilet.
Dan
Old 07-23-2006, 11:49 PM   #5
1960 24' Tradewind
Hey Dan ,
You shouldn't have to change the flange ,and it does look like a house flange
except your should thread on as well as having screws holding it in place.
If it is warped or other trouble you can replace it .common item to get.
Scott
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Toilet Replacement 3Ms75Argosy Sinks, Showers & Toilets 22 02-18-2007 07:51 PM
Rear toilet platform rotten, now what?? MontanaArgy Cabinets, Counter Tops & Furnishings 9 08-14-2005 06:46 AM
Toilet Overflow bentguy Sinks, Showers & Toilets 4 07-09-2004 03:07 PM
toilet doesn't hold water.... Chuck Sinks, Showers & Toilets 12 10-08-2002 10:03 AM
