Old 04-03-2006, 05:57 PM   #1
Hawk_Man's Avatar
1975 28' Argosy 28
Hopkinsville , Kentucky
Toilet Replacement
Hello All, As I go through the refit of The Painted Lady (28' Argosy), I am wanting to upgrade the toilet with a porclain model . A recomendation on a good quality Brand/ Model would be most appreciated.
God Bless and Safe Traveling
Keith & Johnya
Wolfen (Eskimo Spitz)
Hawk_Man is offline   Reply With Quote
Old 04-03-2006, 07:01 PM   #2
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
OlyPen , Washington
Images: 90
Yes - Sealand traveler lite is about the only toilet that will fit in the space. It's a good porcelain model and you can order it from a number of places. I would try PPL. It comes in 2 colors and 2 heights - you probably want the lower one.
Use the search tool on the forums and do a search to sealand toilet. you'll find a number of folks who replaced with this model.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 04-03-2006, 07:06 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Keith & Johnya
The Traveler is a great unit. If you want something a little more 'fancy', Thetford makes tha Aria, which is an electrically operated automatic flush toilet. Very upscale for your coach .
Old 04-03-2006, 07:29 PM   #4
Janet H's Avatar
1964 26' Overlander
OlyPen , Washington
Images: 90
Will it fit in an argosy? I found that there is limited space behind the pot. i wasn't able to find a thetford model that was shallow enough (front to back).
Old 04-03-2006, 07:45 PM   #5
Hawk_Man's Avatar
1975 28' Argosy 28
Thanks for the advice
I will look into both recommendations. Dimensions will be a factor. Electric Mmmmm, Never imagined that being an option.
Keith & Johnya
Old 04-03-2006, 07:57 PM   #6
WayWard Wind's Avatar
2004 25' Safari
Lightbulb you might need????
If you go with the electric model, would you need a generator for when you're not "plugged in" ?
Best,
Home of the Wayward Wind
Bogfrog & Mr. Turbo
If in life you stumble, make it part of the dance
WayWard Wind is offline   Reply With Quote
Old 04-03-2006, 08:02 PM   #7
Janet H's Avatar
1964 26' Overlander
OlyPen , Washington
Images: 90
try this link - they have specs available online. http://www.pplmotorhomes.com/parts/r...nitation-1.htm
we really like our sealand.... it does what it's supposed to do when it's supposed to do it. The install was straight forward and the quality is good. They have a model with a hand sprayer...
Old 04-03-2006, 08:32 PM   #8
lewster's Avatar
Best,
No. It's a 12VDC motor that works the blade valve and water solenoid. You cana use it anywhere you have battery power.
Old 05-15-2006, 02:38 PM   #9
1998 25' Safari
1978 25' Tradewind
Weaverville , California
Toilet Replacement Options?
I am also looking for a replacement toilet but not sure I have the same bathroom configuration as those discussed above. I have a 78 25ft Tradewind with toilet on top of tank between closet and sink (rearbath). Dimensionally, it appears a number of new toilets will fit but Im concerned that some say only the Traveler lite will fit. I dont necessarily want a porcelin bowl and would prefer the larger base of some of the other brands/models. Does anyone have recommendations?
Jim48 is offline   Reply With Quote
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Toilet Replacement 3Ms75Argosy Sinks, Showers & Toilets 22 02-18-2007 07:51 PM
Rear toilet platform rotten, now what?? MontanaArgy Cabinets, Counter Tops & Furnishings 9 08-14-2005 06:46 AM
Toilet Overflow bentguy Sinks, Showers & Toilets 4 07-09-2004 03:07 PM
toilet doesn't hold water.... Chuck Sinks, Showers & Toilets 12 10-08-2002 10:03 AM
