Old 02-25-2008, 06:06 PM   #15
2007 25' Classic
Hydes
Originally Posted by handn
Same question. We have a a 2004 Safari 25. The wife wants a china toilet rather than than the plastic Aqua Magic that came with the unit. Classic's have china toilets. What comes in the Classic and will the toilet fit in our Safari.
The Classics don't have china toilets. At least my 07 25' Classic doesn't.
craftsman is offline   Reply With Quote
Old 02-25-2008, 06:28 PM   #16
_
some of them do...
basically the sealand/dometic traveler lite model noted above (by krazy') came in the 34 classics only.
it is a china toilet...
almost all of the other classics come with the throne you have.
i'm on my 3rd sea land-dometic traveler lite...
the first 2 had faulty bowl seals that stopped 'sealing' after a few months....
so rather than rebuild it (under warranty) they just sent me complete NEW crappers...
so now i've got an extra at home that just needs a gasket replacement...
it's very low mileage, only used on sundays!
cheers
2air'
Old 02-26-2008, 10:40 AM   #17
2007 25' International CCD
2011 19' International
Pleasant Hill , California
So, if I wanted to put the sealand/dometic traveler lite into my 25FB then I am going to have to use a router on the wall due to the 9-1/2" bolt to wall clearance?
Also, are you using the tall or short model? While the taller one would be preferred the shorter one might be better for access to the cabinet behind the toilet.
Finally, what is all this talk about hand sprayers?
BoatBoy is offline   Reply With Quote
Old 02-26-2008, 11:35 AM   #18
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
This is a handheld sprayer that assists in rinsing "product" out of the bowl.
Dave
Fyrzowt is offline   Reply With Quote
Old 02-27-2008, 11:35 AM   #19
tkowalyk's Avatar
2013 27' FB Classic
North Wales , Pennsylvania
Images: 11
Toilet in 25SS Safari
I have a 25SS Safari - and we installed a Sealand low profile China Toilet - and slightly rotated the toilet away from the door -- it is a much better - your knees do not hit the door, but are close
tkowalyk is offline   Reply With Quote
Old 02-27-2008, 12:14 PM   #20
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Sprayers
My first Airstream was the 2005 CCD 22' - it has a china bowl and a sprayer.
In my ignorance I thought my sprayer was broken. Then I found out that it only worked when my foot was on the flusher. Gee, that didn't make a lot of sense, standing over an open drain in July trying to get a little product off of the inside of the bowl, with a wide open sewer - gently wafting fermenting methane up at me...
Then I suddenly realized... wet bath, sink faucet doubles as shower wand... warm water dissolves product faster, THEN you flush. Never used the wand again.
Cleaning the wet bath was super easy too, a couple of scoushes of scrubbing bubbles, on all the surfaces, wipe down, get out the shower wand and rinse all the mess down the floor drain. Wipe the seat dry and leave on the fan so evaporation can do it's thing. Must say I found the shower bigger and had plenty of room when seated - just wouldn't have worked when one wanted to shower and a partner wanted to be seated.
Paula
Old 02-28-2008, 02:29 PM   #21
2007 27' Safari FB SE
McKinney , Texas
Boatboy,
I currently have a Thetford Aria Classic (not electric) in my 2007 27' FB Safari and it fits over the hole just fine. It is an elongated bowl and I have to sit kind of side saddle on it with my knees out the door. My reason for replacing the Aqua "tragic" is because I got tired of getting snagged when I stood up form taking care of my business. I spoke to the factory and got the model number for the toilet that I will install in the next week or so (dometic sealand traveler lite).
Krazyjohnny is offline   Reply With Quote
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Toilet Replacement 3Ms75Argosy Sinks, Showers & Toilets 22 02-18-2007 07:51 PM
Rear toilet platform rotten, now what?? MontanaArgy Cabinets, Counter Tops & Furnishings 9 08-14-2005 06:46 AM
Toilet Overflow bentguy Sinks, Showers & Toilets 4 07-09-2004 03:07 PM
toilet doesn't hold water.... Chuck Sinks, Showers & Toilets 12 10-08-2002 10:03 AM
