Toilet part #2
Removed the toilet today. Not really too bad a job, once you soak the bolts with a rust softener. (almost a stool softener, but not quite) Found it to be in better shape than I expected. The thick rubber ring seal has seen better days, but does not seem to have leaked. The metal flange is quite rusty. Enough that I first thought it was plastic cracked to pieces. Turned out to be enamel cracking off the metal surface. The metal flange appears to be attached to the tank opening with screws, or phillips head bolts. I plan to remove the ceramic bowl from the plastic base next. Gotta get the wife to help on that one. Someone has to catch the springs that are likely to pop out when the two are separated. Possibly take action photos to track them back to where they go. :-) I really would like to keep the original toilet, it being ceramic, but there are certainly advantages to new ones. I could get the tall one without having to add a spacer. The new ceramic ones are rather costly. The saga continues.
cheers, bill b.
bill b.
1969 Airstream Sovereign 31'
2001 F250 7.3 Diesel
