Old 12-26-2003, 05:19 PM   #1
David Hall's Avatar
Toilet Repair
When I flush the toilet the Air Vent or whatever it is, leaks while flushing. I have no ideal what this is or what it is called but would like someone to tell me what it is so that I can get it fixed or replace it. I took it off and apart to find a valve and gaskets that should shut water off I think. I need help. 1961 Overlander....
Thanks...Dave....
Dave
David Hall is offline   Reply With Quote
Old 12-26-2003, 05:38 PM   #2
Images: 59
More info?
Dave:
Can you provide a little more descriptive Info? There may be a vent which is a 1 1/4" pipe caulked into the rear of the base, or are you referring to a smaller, elbow type fitting on the water inlet?
Old 12-26-2003, 06:15 PM   #3
David Hall's Avatar
The thing I'm talking about is above the water on /off valve it makes a 90 deg turn to the back of the toilet, it is 3/8's" plumbing to a 1-1/4 " plug into the toilet. From what I think but don't know, It's like a vent from the toilet back to and above the on/off water valve that shuts down when the water is turn on so the water goes to the toilet. I hope this helps, if not maybe I can get a picture and post it. Thanks........Dave....
Dave
Old 12-26-2003, 09:11 PM   #4
Images: 59
I think what you're looking at is a vacuum breaker, which prevents backflow of water from the toilet if pressure drops in the main water line. A common part that should be available at most hardware stores. Good luck
Old 12-27-2003, 08:04 AM   #5
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
A Picture is Worth a 1000 Words
If you can, Dave, post a picture. I may have one from my '59 that is no longer needed but I don't know what I've got either.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 12-27-2003, 07:20 PM   #6
David Hall's Avatar
Hello to All
I'm in the process of getting a couple pictures up for the Part or parts that I need. I need the name of this if it is still available or a part that may take it's place. I'm new at this so please bear with me. Thanks ..Dave..
Dave
Old 12-27-2003, 07:23 PM   #7
David Hall's Avatar
Like I said I'm new.....Here is the 2nd picture of the Item that I need. ......Thanks.......Dave........
Dave
Old 12-27-2003, 08:00 PM   #8
Images: 59
Repair
Do web search on 'vacuum breaker', or get from a local plumbing supply house.
Old 12-28-2003, 03:07 PM   #9
David Hall's Avatar
Toilet repair
Thanks to all of you, I didn't know what a vacuum breaker was, now I know, Learned something. Thanks.....Dave....
Dave
Old 12-28-2003, 07:21 PM   #10
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
They still sell vacuum breakers like that...
...especially for sprinkler or pool filling systems. You may have to look around to find a smaller one like you need.
Or, try www.mcmaster.com and part number 9903K51
-Don
Old 12-28-2003, 10:21 PM   #11
David Hall's Avatar
Thanks Don, Just what I needed, on order. I was sure having a hard time finding it. ......Thanks....Dave...
Dave
Old 12-29-2003, 07:46 AM   #12
drboyd's Avatar
1978 25' Tradewind
Cool Cool!
Glad I could help!!!
-Don
Old 12-29-2003, 11:51 AM   #13
Images: 59
Toilet repair
Dave:
Just a warning-
If the new vacuum breaker continues to leak like the old one, you may need to check your water pressure regulator (set too high) or maybe put in a small expansion accumulator. These units can leak a little, rather than chance having water from the toilet bleed back into your fresh water lines when you open a faucet.
