Old 07-22-2011, 03:59 PM   #1
Rancho cucamonga , California
Toilet Removel Help Needed
We have a 1977 Silver Streak and are trying to remove the toilet. All the nuts are loosened but something is still holding it. Any suggestions?!
Bmccaulley is offline   Reply With Quote
Old 03-03-2012, 08:14 AM   #2
pawtucket , Rhode Island
Hi Bmccaully, did you ever get an answer? I have a 1960 pacer, loosened bolts on either side of toilet. Can't get it out. Thanks. Karen
kaholler is offline   Reply With Quote
Old 03-03-2012, 09:39 AM   #3
joqin's Avatar
1965 17' Caravel
brooklyn park , Minnesota
toilet removal
I have a 65 caravel that I played the toilet dance to; there may be a rubber or wax or duct seal gasket. if it's been on there along time, it may hold on to it like glue! just keep pulling and rocking and if you break it, a new one is a great investment. I was lucky! to reseal the joint between the trailer and the toilet, I had to use 2 gaskets; the new rubber one didn't quite seal, so I needed to remove the toilet AGAIN and add a little plumbers putty to stop the drips!!
joe q
joqin is offline   Reply With Quote
Old 03-03-2012, 10:12 AM   #4
1974 29' Ambassador
1976 25' Caravanner
trenton , Missouri
sometimes there is a nut under the flush pedal that can be difficult to see
bimpy is offline   Reply With Quote
Thetford Style II toilet model 42059/replacing Lothlorian Sinks, Showers & Toilets 4 08-23-2011 05:07 PM
How do I find the correct replacement toilet? meredith Sinks, Showers & Toilets 1 07-15-2011 12:20 AM
Toilet over laminate? willbrackman Floor Finishes 0 07-11-2011 12:31 PM
Toilet height- too high? SalandViv Sinks, Showers & Toilets 5 05-08-2011 11:06 AM
composite flooring bathroom installation sealing the toilet handn Floor Finishes 1 03-10-2011 06:47 PM
