Old 06-13-2010, 07:36 PM   #1
ridinatlast's Avatar
1978 31' Sovereign
Bella Vista , Arkansas
Toilet removal for 78 Sovereign - help!
Ok, my husband & I can usually figure out how to fix anything. We seem to have a slow leak behind our toilet in our newly acquired 78 Sovereign...on of the few problems we have found.
However, we are only guessing because we are feeling behind it because we can't seem to see how to get the silly thing out. We feel like idiots but we have looked all around and there must be a trick we are missing.
And, from old threads I have read we need to replace the seal when we put it back in...much like a home john.
Can someone tell us how to get the darn thing out?
Lady K
ridinatlast is offline   Reply With Quote
Old 06-13-2010, 08:10 PM   #2
1978 31' Sovereign
I should have included the image of our toilet.
[/IMG]
Old 06-13-2010, 08:13 PM   #3
1978 31' Sovereign
I am having some trouble posting a photo of our toilet but I am trying. Jeez.
Lady K
[/IMG]
Old 06-13-2010, 09:05 PM   #4
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Is it like the one in this link
1978Sovereign1
Here's a link to Thetford information and manuals.
http://www.thetford.com/HOME/CUSTOME...ult.aspx#floor
Old 06-13-2010, 09:47 PM   #5
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Lift the seat and there is a round plug top left.
Remove the plug and there is a 7/16 bolt (I think) straight down you will have to remove it and it takes a long extension or many short ones.
Under the flush pedal there is another bolt once you have removed the 2 bolts the toilet will tilt forward to remove the water line.
Remove the water line and the toilet comes right out.
I think the seal is the same as a home toilet but don't remember for sure.
Garry
garry is online now   Reply With Quote
Old 06-13-2010, 09:53 PM   #6
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Correct info on the bolts if your is like the one in Gary's link. I removed one like that from my Excella recently. Hard to locate if you don't know where.
The seals for RVs are different from home ones, but any RV shop will have them.
Vaughan
Old 06-14-2010, 10:14 AM   #7
1978 31' Sovereign
Thank you all SO much for the helpful info. We did find that plug on top left side of toilet seat. There was a hose right in the way so we will have to dig around and see if we can see the bolt down in there but now we know the others are under the pedal.
We appreciate all of you sharing your experience and I am ordering the 1978 Service (not owners) Manual today - kind of pricey at $60 but I am hoping it will have a lot of this info to help us.
Lady K
Old 06-14-2010, 11:38 AM   #8
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Personally - I prefer one of these wrenches for removing the rear bolt to a socket on a long extension. Use the plug hole to see what your doing....
Shop Kobalt 7-Piece Locking Flex Head SAE Wrench Set at Lowes.com
Rear toilet removal rc707 Plumbing - Systems & Fixtures 5 06-01-2008 12:01 PM
Toilet Removal? sugarloafin' Waste Systems, Tanks & Totes 2 05-24-2007 05:07 PM
Toilet removal: Temporary Chipster Sinks, Showers & Toilets 1 12-05-2005 04:53 AM
Toilet removal advice requested Lockwasher Sinks, Showers & Toilets 5 11-14-2004 09:43 AM
Toilet removal? earlflew Sinks, Showers & Toilets 8 10-17-2004 03:40 AM
