Old 10-17-2012, 10:31 PM   #1
1975 31' Sovereign
Bremerton , Washington
Toilet removal.
How do you uninstall a toilet in a 1975.
Von Randoom is offline   Reply With Quote
Old 10-17-2012, 11:26 PM   #2
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
1. Disconnect the water. be careful, the plastic valve is not super strong.
2. There are two bolts
3. Reach the first bolt through the foot pedal opening and over the top of the foot pedal while you are holding it down with your third hand. You can see it (with suitable body contorsion) through that same opening.
4. The second bolt is reached through the back, but you can't see it. You have to remove the 1" diameter plastic plug in the left side of the top of the toilet and peer through with one eye.
Fun, hunh?
This photo shows the location of the bolts when viewed from the bottom. If you have broken valve, I have a post with details on how to replace it with the currently available valve assembly. The new assembly doesn't have a prong for hooking the foot pedal spring.
Name:	DSCN0071 toilet bolts-s.jpg
Zep
Old 10-18-2012, 12:07 AM   #3
1975 31' Sovereign
1977 23' Safari
In the above post, change "bolts" to "nuts." The nuts are on standard toilet hold down T-bolts.
Z
Old 10-18-2012, 06:53 AM   #4
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Ok, ok, ok, Zep, I have a follow-up question. The clean slide valve in our Aqua Magic (same model as yours, I think) started leaking, so I've removed the toilet and have the slide valve repair kit ("Thetford 09872 ABS SVC Repair Package") ordered. Here's the problem: I have no documentation and can't find anything on the dinosaur Aqua Magic online. And I have the feeling that the repair kit doesn't have any instructions, either. So have you redone your slide valve? Any advice?
Lynn
WBCCI 21043
Old 10-18-2012, 08:24 AM   #5
1975 31' Sovereign
1977 23' Safari
Hope these photos help a bit. The gasket that I've pointed to only seals the valve/slider unit to the throat of the toilet. I haven't gotten inside that unit to see how the slide valve works.
The first step is getting the valve unit off the bottom of the toilet. From the photo in my post above, it looks like there are 4 stainless screws--that doesn't look right, since they aren't symmetrical around the throat. I don't recall if there are others.
Name:	DSCN0072 slider 2.jpg
Name:	DSCN0074 slider 1.jpg
Good luck,
Zep
Old 10-18-2012, 08:42 AM   #6
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Ah, ok, it does look like you can remove the four screws without having the mechanisms fly apart from the spring load. That's pretty good news! Thank you for posting those pics, Zep!
The repair kit I ordered appears to include a set of four gaskets, though those may be for slightly different models. I'm not going to tackle this until the parts arrive, presumably next Tuesday. (Yep, I ordered a new flange seal, too.)
Lynn
WBCCI 21043
Old 10-18-2012, 09:14 AM   #7
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I had the flappers seal leaking on mine after the water evaporated in the bowl and the seals dried out. I used some O ring lube that I bought for my pool filter to coat the seal area and it has not leaked in two years. I also check the water level in the bowl more frequently when the trailer is stored.
Richard
Old 10-18-2012, 10:42 AM   #8
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
I think mine crapped out (what a pun!) when there was a small amount of ice around the slide valve. I stepped on the pedal, and the ice caused the rubber to rip. Cute trick, eh?
Lynn
WBCCI 21043
