Old 12-14-2005, 12:16 PM   #1
65 overlander's Avatar
Images: 22
Toilet refit
Once again I tried to figure it out on my own , and could of saved time by asking the forum! My toilet on a 1965 Overlander works great, but I kept seeing gobs of silicone, where there could be a proper fix. The first was the rubber seal for the vacuum breaker line.Took a Rbber plg, and lathed it down to a great fit. The second is this hose going from the disk valve to a hole into the bowl of toilet. The fitting on the inside of bowl is the stainless,3/8" fitting, which then goes through porcelain, to the PVC 90 fitting. Being that I cant find a brand on the toilet, I'm asking for help. By the way, I thought that just restoring a vintage trailer would be a hobby , not a passion!
Thank You once again! Jeff
ID:	17060   Click image for larger version
65 overlander is offline   Reply With Quote
Old 12-14-2005, 01:49 PM   #2
Uberlanders's Avatar
1968 26' Overlander
Wenatchee WA , Cape Cod
It is probably a Thetford, that is what we had in the 68 Overlander. We replaced it with a new one. There should be a thread about it somewhere with people's suggestions.
Jim & Kathleen
1968 Overlander - WBCCI #5793
Uberlanders is offline   Reply With Quote
Old 12-19-2005, 11:10 AM   #3
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
65 O,
That is an awesome pic.
My '66 has a rotted floor back there and the dumper (toilet and tank) fell out when I brought it home. So we do not use the dumper and just go to camp sites with bathrooms. However your pic (and I saved to to my puter) shows a lot of the detail I will need in the future.
Again thanks for the nice shot.
>>>>>>>>>>>>>Action
Toilet Replacement 3Ms75Argosy Sinks, Showers & Toilets 22 02-18-2007 07:51 PM
Rear toilet platform rotten, now what?? MontanaArgy Cabinets, Counter Tops & Furnishings 9 08-14-2005 06:46 AM
Toilet Overflow bentguy Sinks, Showers & Toilets 4 07-09-2004 03:07 PM
toilet doesn't hold water.... Chuck Sinks, Showers & Toilets 12 10-08-2002 10:03 AM
Toilet valve problem Charles Q Treichel Sinks, Showers & Toilets 1 09-04-2002 10:59 AM
