Old 11-19-2003, 09:12 PM   #15
rfield54's Avatar
2002 19' Bambi
1989 29' Excella
1980 28' International
Avon , Colorado
Images: 106
Send a message via AIM to rfield54
Wink
You won't be sorry with your upgrade. After you've jimmy-rigged the slots in the flange for the 3rd and 4th bolts, make sure you set the toilet in position and turn it to the desirable angle. Assuming the retainer screws aren't installed, the flange should turn easily with the toilet. Then, carefully remove the toilet and set the 8 retainer screws. You'll probably need to drill new holes for these screws. Good luck. - Roy
rfield54 is offline   Reply With Quote
Old 11-20-2003, 06:00 PM   #16
Stinky's Avatar
sealand
Hey where did you find the sealand in phoenix, I am in the market for one.
Stinky is offline   Reply With Quote
Old 11-21-2003, 09:32 AM   #17
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Thumbs up
http://www.foothillsrvparts.com/
You'll be talking to Ken, the owner. Tell him I sent you. (Like that will do any good!) He seems like a really good guy, and he's got much better prices than most of the RV places around.
I had to run when I picked up my toilet, but I'll be back to spend some money there.....
-Don
Old 01-29-2004, 08:46 PM   #18
another project's Avatar
1969 31' Sovereign
Gilbert , confusion
yea, me too i just removed the old aqua magic last weekend. It has some broken parts underneath and could probably be fixed but, I think I would just as soon get a new that hasen't been used yet....(trailer is new to us)
Rich
another project is offline   Reply With Quote
Old 01-30-2004, 09:48 AM   #19
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
FWIW - parts are still available - I just bought a complete new mechanism for mine - the reason I fixed mine is because to me it was the easiest thing to do - just take it out, put it back together and I'm done. Lots of lysol when I bought it though
Ken J.
Ken J is offline   Reply With Quote
Old 01-30-2004, 12:19 PM   #20
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
If you all should need advice on the Sealand change out drop me a line and I'll let you know how I did it.
Pretty easy job except for the cap.
Luck be with ya.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 01-30-2004, 01:28 PM   #21
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Re: flange
Originally posted by 3Ms75Argosy
I'm not sure about the bolt pattern of the Sealand, but when I took off my toilet, there was a flange that could accept studs in about five/six different areas - the holes were slotted - I think that should give you enough room to put four studs on in the areas needed.
In the photo, each "dark spot" around the flange is a slot for a stud.
Rubber gloves make the install much more sanitary too!
Marc
That picture just cleared up a lot of my confusion. Out sealand was installed wrong. We had NO screw on to the tank tlange at all and the bolts for the tolet were into the wood decking. the outer flange with the bolts was not there. It was sealed with wax ring.
Guess where some of the worst floor issues were?
I did find the tank screw on peice at West marine. I just need to find the outer ring now.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 01-30-2004, 03:08 PM   #22
Images: 55
We're putting in a Sealand Treveler in our '73 and had the same flange issues. We called Sealand and discovered that there is an adapter available for these. I haven't yet installed it , but it is supposed to prevent you from having to muddle around with our existing flange and possibly causing a leak (when full of course).
Hope this helps.
Tripp
Tripp is offline   Reply With Quote
Old 01-31-2004, 07:43 AM   #23
HP9K's Avatar
For what it's worth, I replaced the orignal Thetford in my A/S with the new Bravura last year. If you have the room for it, it is an easy exchange. The whole job took less than an hour. The Bravura does stick out to the rear a bit more than the older one did, but I had four or five inches behind the old one to start with.
I went ahead and added the optional riser as well. I'm 6'4". so the extra two inches of height is nice. It makes for a nice finshed look around the base.
HP9K is offline   Reply With Quote
Old 02-10-2004, 04:15 PM   #24
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Sealand weight
Does anyone know the weight difference between the Sealand low profile toilet and the plastic Bravura or Aqua Magic? The porcelain must weigh substantially more than plastic.
I am concerned with weight because of the rear bath comfiguration in my 1971 Tradewind.
If it is 20lbs or more, then I would worry, or should I ignore the weight issue altogether?
I want to buy a new toilet this week, any help woould be appreciated.
Uwe
www.area63productions.com
Old 02-10-2004, 04:27 PM   #25
HP9K's Avatar
I tried to find a shipping weight for the Bravura, but Thetford doesn't list a weight - neither did Camper's Choice or Camping World.
It wasn't heavy - it's all plastic. I'm guessing maybe 20 pounds.
Old 02-10-2004, 05:28 PM   #26
New Borockton , Alabama
Images: 21
I just weighed the Bravura. 18 Lbs. I have a brand new parchment high profile one that I bought for my 94 but sold the Airstream before I installed it. It's still in the box with a new flange seal. If anybody wants it I'll sell it for $130 and I'll pay for the shipping.
Randy
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 02-10-2004, 09:23 PM   #27
rfield54's Avatar
2002 19' Bambi
1989 29' Excella
Avon , Colorado
Images: 106
Re: Sealand weight
The Sealand Travelite is suprisingly light, nothing like a home unit. I'm guessing it weighed maybe around 5-8 lbs more than the Thetford it replaced (25 lbs total?).
Old 02-16-2005, 07:54 PM   #28
Luck be with ya.
Just got the Sealand and haven't removed the Aqua Magic - bolts to floor. Those tips on how you did it could come in handy! (I have 78 Argosy mid bath - should be same type floor.
ca_argonaut is offline   Reply With Quote
Toilet changing tips... drboyd Sinks, Showers & Toilets 2 07-18-2006 01:28 PM
Toilet Overflow bentguy Sinks, Showers & Toilets 4 07-09-2004 03:07 PM
64 Swirlomatic toilet MW64OVERLANDER Sinks, Showers & Toilets 1 10-27-2003 09:57 PM
Toilet replacement Globestream Sinks, Showers & Toilets 2 09-23-2003 11:52 AM
remove/reinstalling the toilet Chuck Sinks, Showers & Toilets 7 07-28-2003 02:44 PM
