Old 09-13-2011, 11:49 AM   #1
1978 Argosy 30
prospect , Maine
Toilet problem?
Not sure of the correct name but the flush flap that stays closed until you flush the toilet. It stopped closing all the way. Is that part replaceable or do I need a whole new toilet? Thanks for any feedback!
thegirouxs is offline   Reply With Quote
Old 09-13-2011, 11:53 AM   #2
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Well, there is a technical term for it but I have no idea what it's called.
Generally, the solution is to clean the track or groove that the flap closes in to seal the toilet from the tank. Sometimes it is closed too early and pushes TP or OTHER debris into the groove and not allow the flap to properly close. You at full hookups??? sometimes you can use the spray wand to wash the groove out. If not then a small soft scrub brush will do. Worst case is a wire the same size as the groove - drag it around the groove to clear it out. Prevention is to make sure all the goodies are past before closing.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 09-13-2011, 03:57 PM   #3
1978 Argosy 30
prospect , Maine
Thank you for your reply. I will give that a try. Thanks again!
Potential Problem? Pictures included palmtreegirl 1990 - 1993 Excella 51 08-12-2013 10:50 PM
Thetford Style II toilet model 42059/replacing Lothlorian Sinks, Showers & Toilets 4 08-23-2011 05:07 PM
How do I find the correct replacement toilet? meredith Sinks, Showers & Toilets 1 07-15-2011 12:20 AM
Toilet over laminate? willbrackman Floor Finishes 0 07-11-2011 12:31 PM
Toilet height- too high? SalandViv Sinks, Showers & Toilets 5 05-08-2011 11:06 AM
