Old 03-29-2010, 03:12 PM   #1
Gypsy Jo's Avatar
1977 28' Argosy 28
Bullhead City , Arizona
toilet parts what do I need
Toilet in sob mh will not hold water It is an aqua magic have been to Marks rv parts and looks like I will need a blade seal , new blade, and a new floor seal anything else? and how hard is the fix?
Gypsy Jo
1977 Argosy 28' Motor Home
Gypsy Jo is offline   Reply With Quote
Old 03-29-2010, 03:22 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Before you buy anything. Take a strong coat hanger cut it so you have the bottom straight piece and bend a 1 in. right angle at one end. Bend the other end to give you a grip. Open the valve and work the hanger around inside the valve where blade sets. Often paper will get crushed into the valve seat and the hanger may snag it and pull it out.
If you start to get paper it may be just as easy to remove the toilet and work from the bottom to clean the groove
2004 Excursion 4x4
Old 03-29-2010, 03:30 PM   #3
Gypsy Jo's Avatar
1977 28' Argosy 28
Have tried that fix. read about on the forums .Didn't work, to bad .Much easier fix than what I am looking at now.
Gypsy Jo
Thetford Toilet parts boltos Plumbing - Systems & Fixtures 3 02-11-2010 02:18 PM
Toilet Parts- Help! artemis917 Sinks, Showers & Toilets 23 10-17-2009 09:25 AM
1968 Overlander toilet parts 68-Ovrlndr Sinks, Showers & Toilets 5 10-12-2009 06:34 PM
Toilet Parts rc707 Sinks, Showers & Toilets 1 06-01-2008 07:37 PM
65 Safari Toilet Parts? Kevo Sinks, Showers & Toilets 3 12-31-2006 10:38 PM
